All other sounds are ok on the phone - but when I receive a call I can barely hear them. Sound up to max level - ringer works, music works just cant hear caller.
SOURCE: incoming call problems
Could be that it's just a software hickup: press menu and on/off button togetherfor 5 sec. If it's the same after the restart you need a new earspeaker. You can also use a headset, if it works with the headset, you definitely need a new earspeaker.There is a step by step guide too that explains a little bit at eachsteps what you have to do : iPhone speaker repair. You can buy the touch screens online too. There are also iphone repair companies that do it for you.
SOURCE: The speakers on my iphone 3G are barely working Im
Check volume settings, If not, you'll have to replace speaker
SOURCE: I can't hear peoples voices when they call. The volume only works for the ringer
If you want to change volume of the caller's voice, then try adjusting the volume control WHILE you are actually talking on the phone during a call.
If you try to adjust the volume when there is no call in progress, then the volume controls will only change the ringer volume.
If you provide the exact model number of your particular device, then we may also be able to provide you with the User's Manual for your phone.
I hope that was helpful Loli.
Good luck and take care.
Joe.
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
