Wont connect to internet all lights are green except internet
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledi click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
hope this helps
SOURCE: speedstream 5100
red light on DSL implies no ADSL communication to ISP. Check your phone line connection and make sure there are filters on all the other phone equipment in the home
SOURCE: router to connect or sub the speedstream 5100
Option 1 (easy)
you could buy a switch or router and put in line with your modem.
you will have to set up appropriate networking on the xbox
DSL --> MODEM --> SWITCH <-- PC
^---- XBOX
Option 2 (harder)
you could get a wired/wireless AP (Access Point) for your PC and run ICS (Internet Connection Sharing) through Windows. connect the XBOX through your PC
SOURCE: how do i connect my speedstream 5100 to dsl aftr i turn it on?
Call your service provider.
i.e. Time Warner, Cox cable, Verizon, etc.
Talk to Tech Support. They'll run a line test and guide you through any problems.
Let me know if you have any other questions.
Best of luck!
SOURCE: I have a 1.5 Mbps line and the Speedstream 5100
I am not terribly familiar with the device itself, but if there are no options in the configuration menu to set that manually on your side, odds are it's auto-detecting what you are getting from your provider.
DSL is kinda finicky when it comes to distance, so could be that you ordered 1.5Mbps and they are only able to give you 288Kbps transfer speeds.
To find out what your download and upload speeds are actually functioning at (in case the device is just reporting incorrectly) go to http://www.bandwidth.com/tools/speedTest/ and run the test.
SOURCE: can"t get on the internet using 5100 speedstream modem my
in your browser type 192.16.0.1 and it will take you to the modem admin page.
Press the check connection button and it will tell you how your connections are doing. If it shows DSL/Internet down, then most likely your ISP is down 95% likely), or your modem is bad (happens pretty often with these things)
If it doesn't take you to the page, try using 10.0.0.1
some of the newer 5100s have that as their address. Same options and advice.
