Question about MTX Thunder 3401 Car Audio Amplifier
Mtx thunder 3401
Wiring diagram
5 Related Answers
hoyzee1
  • 150 Answers
SOURCE: MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Posted on Jun 04, 2009
Anonymous
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Posted on Jan 23, 2010
Anonymous
SOURCE: wiring details
thunder 81000D not bridgeable,i have two daul voice coils kicker cvr how would i wire them up?
Posted on Jan 29, 2010
kcarmax
Kevin Simoneau
  • 30 Answers
SOURCE: i have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Posted on Mar 01, 2010
Anonymous
  • 6 Answers
SOURCE: MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Posted on Apr 06, 2010
Mtx thunder 2160 diagram
find the mtx thunder website and send them a email.
Nov 06, 2013 | Car Audio & Video
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
What is Positive and what is Negative
Hi Mason.
Are the positions colour coded in any way?
Red = Positive
Black = Negative
I've looked at some photo's from the website and at a guess I would say that yours are the push on crimp types, so no colour markings.
Have a look at the pdf wiring diagram they supply here as it may shed some light on things:
MTX Thunder US-XT12-44
I've looked over loads of forums but none seem to mention the wiring of these subs.
Understandably you want to get this right as they are a very nice set of subs when they're up and running.
If all else fails try looking at the MTX contact list and ringing one of their supported dealers for more info.
Regards
Mike
Mar 21, 2010 | MTX Thunder 6000 T61044A Car Subwoofer
Wiring details
Hello bpuentes,
Here's a link to the wiring diagram PDF.
http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/TA81001InstallWiring.pdf
Hope this helps.
Mar 30, 2009 | Car Audio & Video
Wiring details
Mar 30, 2009 | MTX Thunder 81000D Car Audio Amplifier
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
My amp went out and i cant figure out y
Kind of a vague problem description, can you be a little bit more specific. What problems you are experiencing, how many speakers/subs were you powering with it, does it show that it has power, did you check the fuses?
Jun 29, 2008 | MTX Thunder 3401 Car Audio Amplifier
Fuses
check you spkr wiring in put if they are cross
May 25, 2008 | MTX Car Audio & Video
Ground Wire Hook-up
MTX has the hookup diagram here: http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/RTP251D_InstallSheet.pdf If you have the original wiring harness, the ground wire is normally black. The amplifier case or chassis is ground connnected on amps I've seen as well.
Aug 06, 2007 | MTX Thunder 251D Car Audio Amplifier
MTX Thunder 3401 Car Audio Amplifier Logo
Top MTX Car Audio & Video Experts
Marvin
Marvin
Rob Beech
Rick Wrieden
Rick Wrieden
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
