I've had it for a day and it's out of charge I've tried charging it but it isn't working also the red led light that says its charging isn't showing
SOURCE: Charging
just open the main board
and clean with solution
and give a little bit of heat with smd
SOURCE: not charging
We need a charger for this headsets since I am looking for a charger for mine
can you post chargers on the accessories model F-0399A.
thanks
George
SOURCE: The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
SOURCE: GN 9350 Headset won't charge, blue light remains off
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
