Question about Polaroid iZone 300 Digital Camera
2 thin cables white and black; came off the circuit; where I should solder it to?
I have a Polaroid izone 300 that I opened to change its battery but 2 thin cables white and black; came off the circuit but the other 2 ends are still on the white plastic side. I forgot where they go on the circuit can someone show me where I should solder it to? I have posted a picture indicating where I think it might go which is similar to another picture I found on this site from this device. Check to picture http://i1144.photobucket.com/albums/o494/ubuntusaurio/DSCF0540.jpg
  • Fernando Rueda Jul 10, 2012
    The picture I posted is from the camera I own not the picture I say is similar, come on 2 wires and 2 possible spots I need info as to which one is for the white and which one is for the black cable.
6ya staff
SOURCE:
Anonymous
  • 1463 Answers
SOURCE: Users Manuel
hi
try here see if this one helps you Polaroid iZone 300 Digital Camera User's Guide
riz.
Posted on Jan 31, 2009
Anonymous
SOURCE: Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Posted on Feb 21, 2009
Anonymous
  • 31 Answers
SOURCE: i need to download users guide for a polaroid izone 300
ok on the side were u have the screen do u see the circle ok you press the lleft arow amd the flash should be onif not uyour camera is not working with the flash
Posted on Jul 25, 2009
Anonymous
  • 72 Answers
SOURCE: can u send me a manual for Polaroid iZone 550
http://www.manualnguide.com/manual-get/17815/ you should be able to download it from here
Posted on Aug 06, 2009
Keynan
Ran Kedar
  • 977 Answers
SOURCE: where can i download a user manual for a polaroid izone 300
Hi!
You can the manual right HERE!
Cheers,
Pelu.
Posted on Mar 17, 2010
I lost the charger and i dont know how to charge it now
http://www.bestlaptopbattery.com/b.cfm/Digital-Camera/POLAROID/izone-300/CH3450-.htm
this is a replacement charger for the model ..but if I was in your place I'ld try to see if connected to the usb cable its actually charging the battery ..try different choosing in the camera when connect and see if the battery gives sign that it is actually charging ..some mobile phones and camera do that when plugged..
Jun 01, 2010 | Polaroid iZone 300 Digital Camera
Where are the batteries in the polaroid izone 300
The battery is inside the camera. It is very small, and part of the motherboard. In other words, if this camera's battery life is short, your camera is dead.
Nov 10, 2009 | Polaroid iZone 300 Digital Camera
Users Manuel
Go to polaroid.com, select digital cameras and follow the prompts. Eventually you will be able to select the manual for the izone300-301. Peace
May 06, 2008 | Polaroid iZone 300 Digital Camera
Izone 300 - won't keep a charge. Can I change the battery? Where do I get one and how do I do it?
I have the same problem with my izone 300. I charge it for approx. 2 hours and it says that it's done charging but the battery only lasts for about 15 minutes.
May 01, 2008 | Polaroid Cameras
Changing battery..can't find
I took my izone 300 apart and replaced the battery with one purchased from Digiplant on Ebay for $9.98, shipping included. The battery is a Lithium Polymer 3.7 volt, 280 Mah, but I used a 3.7 volt, 550 Mah. It improves the battery life immensly and the flash never fails like it did on occasion when it was new. Hope this helps everyone looking for a replacement battery.
Apr 30, 2008 | Polaroid iZone 300 Digital Camera
Polaroid Change Battery ?
to answer your question on charging your camera with your pc you can if you have the drivers installed on your computer it will let it charge through the usb. as for your second question about being able to replace your cameras battery: well the answer is that it's not possible to unless you either send it to the company to replace it should or when it fails. they will charge you a fee if the camera is out of warranty or the alternative is basically opening the camera and finding a similar battery. should you decide to open your camera than this is the possible solution that i came up with for replacing the battery.
http://www.fixya.com/support/t559753-changing_battery_find
hopefully this helped answer your question.
Mar 17, 2008 | Polaroid iZone 300 Digital Camera
Polaroid izone 300 battery
From what you say I imagine this is built into the case with no opening to allow removal. So that it is recharged in situ. It that right. If so Polaroid is the only place to go- unless you can open up the camera to see what the battery is like. I imagine that in fact it can only be a standard type of battery but perhaps modified to fit he Polaroid housing. Have you actually checked Polaroid Tech Support Team re this
May 24, 2007 | Polaroid iZone 300 Digital Camera
Cameras Logo
50 people viewed this question
Top Polaroid Cameras Experts
Ekse
Marvin
Marvin
LP
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
