Question about Samsung Televison & Video
Samsung pn51d490 51 plasma tv - Samsung Televison & Video
Posted by zigg43 on
    Top Expert:
  • Samsung Master
  • 76,416 Answers
What is the fault with your Plasma TV? You haven't provided any details of problem you are facing to your Plasma TV. Anyway, get in to this site named 'electro-help'. Faults with plasma TVs are described there. In most cases, all plasma tV will have similar problems, and repair work to them will also be the same. Just check this link, and select the site named above for details.
Posted on Jul 09, 2012
5 Related Answers
Anonymous
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Posted on Oct 24, 2008
Anonymous
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
techbuster
INDIRA KUMAR
  • 5081 Answers
SOURCE: SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Posted on Jul 04, 2009
Anonymous
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
Anonymous
  • 28 Answers
SOURCE: error diffusion on Samsung 50" PLASMA TV
Yes the diffusion problem on your tv is due to the pdp panel aging. What you can try is readjusting the VSCAN voltage, there is a test point marked VSCAN using a DVM you can first check the voltage, should be around -- 190 turn the adjustment counter clockwise this should reduce the voltage, watcthing the picture turn control untill the sparkling pixels stop. That should do it. The panel is starting to age this may occur again until you can't adjust it out meaning a bad panel.
Posted on Nov 08, 2010
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
Jan 05, 2016 | Samsung Televison & Video
Plasma tv repair
? 0:59
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
What is the red dots or haze in my picture. Samsung pn51D490. what's the fix?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 23, 2015 | Samsung Televison & Video
I had vertical line on the right side of screen was white would come and go. I tapped the TV a few time then the screen went. You can't turn on or off
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Type in the brand name and type of your device, in the search box [at the top right] of the display window. It will make surf easy.
Jun 12, 2015 | Samsung PN51D490 3D Plasma TV
Wont turn on but tries too come on,power light blinkink
Internal power supply failure. Was there a lightning storm in your area recently or utility work being done recently? This two things usually kill TV's and other electronics with surges when power is restored. If the set is under warranty call the manufacture, if not, call you homeowners insurance agent to see if the damage is covered w/or w.o. deductible. At least you can get something toward repair/replacement costs. Future fix, purchase and install a surge arrestor in your main AC panel for the whole house or buy a power strip with a built in surge filter/protector for your expensive equipment.
Jan 23, 2014 | Samsung PN51D490 3D Plasma TV
Connecting my Wii to a Samsung plasma TV
Press input/source on your TV remote until you are on the right input. Make sure the Wii is on.
Apr 16, 2012 | Samsung Pn51d490 51-inch 720p 600hz 3d...
Can I get the best calibration settings for this model?
Hi, The best calibration settings vary TV to TV because it depends on what looks good to the person as well as the type of room you're in. If you can't seem to find settings you're happy with there's many services that can professional calibrate TVs to your liking.
Aug 29, 2011 | Samsung PN51D490 3D Plasma TV
Televison & Video Logo
233 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
