Question about Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo
MY Panasonic combo TV has no picture (black screen)
Tv was working fine an hour ago, turned it off and when I turned it on again I have no picture. VCR/DVD TV all work fine as far as loading playing sound, but no picture. When I turn off the TV you see the brief flash of colors in middle of screen. Could you tell me what it sounds like is wrong and approx. cost to fix. Is it worth fixiing?
Posted by drinktheberr on
1 Related Answer
Anonymous
  • 58 Answers
SOURCE: when turned on only gets a straight line of color in middle of screen
also on these sets, the vertical I.C. gets cold solder joints.
resolder them before replacing the I.C.
guy9
Posted on Jun 10, 2008
Green and black screen when I use turn Direct TV box
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
My LG 37LC2D picture suddenly goes black and then if I bang on the corner of the set sometimes the picture will return. What is wrong with my TV?
could be the power supply card(s) is unseated..open it up if you dare and re-seat and/or maybe remove and clean the card edge connector contacts with an eraser
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
1helpful
TV is connected to cable; when we have a picture it is terrific. There are several times during the day when we have audio but screen is black. Unplugging and waiting an hour or more sometimes helps but...
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Turn on tv, no picture no sound, shined light into screen,nothing
Check your connections and scart leads, take them out and put them in again. It may be a loose lead or maybe a faulty lead, swop them over to see.
My panasonic TV has sound but no picture
same problem here mine is not a plasma just normal tv was working all fine turned it off came back in an hour turned it on just black screen all channels work with all sound
1helpful
53SDX20B Projector TV - No Picture
It was condesnation from moving the TV from the cold outdoors to the warm indoors. I let it warm up for about 2 hours and then it was fine.
Screen Goes Black After About an Hour
Check the power board inside the TV, possible bad capacitors. I just had them replaced on mine.
3answers
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Open Questions:
Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
