Cable replacement on six-sheet crosscut shredder Executive Machine EPS-611X?
Fairly simple fix then; figure out what length of cable you need (or would like to have if you need something a little longer (like 1 or 2 feet more)) and run down you your local hardware outlet; a place like Lowes, Home Depot or Ace Hardware and pick up a 2 or 3 wire replacement. Make sure it is th same guage wire inside. This will involve opening the unit to install the new one. Take the head unit off, open it and see where the wires from the cable attach to. Make a drawing or take a picture of it before you take things apart and along the way so that reassembly with be easier. Disconnect the old broken cable, and connect the new one. If it is solder to a circuit board, or soldered to the switch, cut the wire back (the old one) so that you can splice the new cable to it. If it uses little connectors, you can disconnect it, and take them along when you go to get the new cable and see if they have similar connectors you can use on your new cable. Reassemble it, and test it. Should be a pretty simple fix. Let me know how it comes out. If you need any additional help, just post it here. -Coss-
