I DONT KNOW HOW TO PUT IN CODES WITH MY GE UNIVERAL REMOTE CONTROL. IT HAS NOT NUMBER OPTIONS SO HOW DO I PUT IN MY CODE 0062 WITH NO NUMBERS ON THE REMOTE.??? THERE ARE NO NUMBER KEYS ON THE REMOTE AND I DONT KNOW HOW ELSE TO PUT OR INSERT NUMBERS, I JUST BOUGHT ONE TODAY AND I DONT KNOW HOW TO PUT IN THE CODE FOR MY SMALL SIZE SYLVANIA TV. CAN SOMEONE PLEASE HELP ME AND TELL ME HOW TO PUT IN THE CODES ?? THERE ARE NO NUMBERS ON MY REMOTE.
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
SOURCE: RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
625, 705
0049 0097 0110 0004
0268 0012 0108 0180
