Question about Mad Dog Multimedia MegaSTOR (MD-16X3DVD9-8X) DVD RW Dual Layer Burner
Reset button for Mad Dog Multimedia, where is it?
5 Suggested Answers
Anonymous
SOURCE: MacBook and Mad Dog Multimedia Compatible?
I have been using my Mad Dog External CD/DVD burner for serveral years now on both Mac & PC. However, I do have intermittant issues when the computer recognizes the Mad Dog but my software does not (Toast). There is no driver for Mac as far as I know. I called Mad Dog one time and they rudely suggested that Mac does not need a driver and that I should know that. No help at all!!! I will try the suggestion for PCs to turn everything off, turn on the Mad Dog, then boot my computer and see if that works. Does anyone else use a Mac and have more solutions?????
Posted on Oct 09, 2008
Anonymous
SOURCE: Mad Dog USB DVD-RW not recognized
I have had a similar problem to this one in that when I turn the device on if my computer is already turned on, it does not show up in the list of available storage devices.
I discovered the cause of the problem.
Whenever I would try to use the DVD-RW/DVD-ROM, I also had another external storage device connected, being my mp3 player. I disconnected the mp3 player, left the DVD drive turned on, rebooted my system, and when I went into "My Computer", it showed the DVD drive connected, with the letter I had assigned it ("D", since the CD-ROM and CD-RW drives were assigned the letters "H" and "I", respectively. Don't ask how. I have no fargin' idea.). I decided to test something out. I put in a DVD, watched a few minutes of it, took it out, then turned the device off. I reconnected my mp3 player, then turned the DVD drive back on. I opened up "My Computer", and after it took a minute to locate all drives, it found the mp3 player, but not the DVD drive. I unplugged the mp3, rebooted the system, and the DVD showed back up.
In short, if you have another external storage device connected to your system, like an mp3 player, external hard drive, memory card/stick reader, digital camera, etc., disconnect that device first, then turn on the external DVD drive. Double-click on "My Computer" (if you are using Windows), and it should show up. If not, reboot your system and then open up "My Computer". It should be listed then.
Posted on Feb 18, 2009
Anonymous
  • 166 Answers
SOURCE: need drivers for my mad dog multimedia dvd burner
Have the same dvd burner. In Windows xp pro, it finds it automatically. make sure the jumpers are set correctly. Iif you are using a different operating system, let me know.
Posted on Sep 03, 2009
lock123
Andrea Lock
  • 6831 Answers
SOURCE: Do I need software to get my comp to recognize a
Hello
Depending on which version of windows you are using, you might need to install the drivers for the device.
I know XP and older versions have a mush smaller internal driver database than windows vista or windows 7.
You don't necessarily need to install software to operate the device, just need the driver installed, then your computer will recognize the device.
Hope this can help you.
Kind regards
Andrea
Posted on Nov 15, 2009
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: I have a mad dog
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 02, 2011
Manuals
Mad Dog Multimedia (MDMM) ceased to exist in 2008 - driver and technical support from this company no longer exists.
Aug 19, 2012 | Mad Dog Multimedia Megastor Computers &...
Mad dog multimedia MD N18BA 128LD
The best I could find was an ad for one on ebay, $14.85
https://www.ebay.com/itm/Mad-Dog-MD-N18BA-128ld-Agp-Video-Card/171594627861?hash=item27f3d63b15:g:KVIAAOSwkNZUke-C
Jan 24, 2018 | Computers & Internet
Need manual for mad dog multimedia external wiring harnness
Unfortunately, Mad Dog Multimedia went out of business years ago, and no longer provide support services or documentation for any of their products.
Unless you can find another one of these external drive cases on a sale rack somewhere, or being sold used by an individual, your chances of finding the original manual are extremely slim.
May 03, 2011 | Mad Dog Multimedia USB 2.0 External Drive...
Can i use Mad Dog Multimedia Predator 5.1 DSP on my win 7 computer?
How to set up sound card Mad Dog Multimedia Predator on my win 8
Oct 21, 2010 | Mad Dog Multimedia Predator 5.1 DSP 6...
Need drivers for predator 5.1 sound card for windows vista 32 bit.
theres no drivers available for vista. Windows XP and below only
visit details here:
http://tech.yahoo.com/ps/mad-dog-multimedia-mad-dog-predator-5-1-dsp/1991618858
visit the drivers here:
http://driverscollection.com/?H=PREDATOR%205.1&By=Mad%20Dog&SS=Windows%20XP
Sep 30, 2009 | Mad Dog Multimedia Predator 5.1 DSP 6...
Need drivers for my mad dog multimedia dvd burner
Sep 03, 2009 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Mad Dog Multimedia Dominator FX 5600 is dead
The company has went out of business. Sad to say but you'll have to purchase a new video card. Sorry.
Feb 14, 2009 | Mad Dog Multimedia Dominator FX 5600 (128...
According to http://www.mdmm.com/spec.php?productid=160 (check the requirements tab, note that it doesn't work on firefox due to bad coding), it only supports Windows 2000 and Windows XP (even though it doesn't say so, it's likely it's also supported by Windows 98 and Vista) but unless someone made drivers for mac os x, it doesn't look like it'll work.
Dec 17, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Mad Dog Multimedia MegaSTOR (MD-16X3DVD9-8X) DVD RW Dual Layer Burner Logo
Top Mad Dog Multimedia Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
