Question about Dryers
Dryer quit heating suddenly.
I have a Kenmore 70 series dryer that, without any symptoms, stopped drying. Everything else seems to work.... just no heat. Is there a fuse for it? If so, where?
  • Dryers Master
  • 8,220 Answers
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 09, 2012
6ya staff
SOURCE:
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Posted on Aug 12, 2008
Anonymous
SOURCE: Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Posted on Oct 06, 2008
Anonymous
Unplug and turn off the gas feed. The fuse is located in the back of the series 70 attached to the lint housing near the bottom. About 1-1/2 inches long. Easy to remove, only two contact wire attachments. Note which wire goes where. Under $10.00 at an appliance parts store. Start with this fix.
If still no heat take out the ignitor assembly, located in the front, lower left. It is attached to the base of the dryer by 3 screws, the gas feed and two electrical wires with removable metal attachments (note which attachment goes where). The entire assembly will come out and the ingitor is attached to the front end. I took mine to the appliance parts store and it tested OK so it was the fuse. The owner helped me locate the fuse and suggested I try this first. The ignitor coil is about $25.00.
Both of these were easy enough for a novice (like me) to do. It saved a lot of money.
While the dryer was open I vacuumed out all the dust and lint and checked the integrity of the belt.
Good luck.
Posted on Oct 07, 2008
Anonymous
SOURCE: Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
James Chandler
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 series dryer won't dry
If the dryer is heating any at all you have a blocked or restricted exhaust problem. Is it not drying with little amount of warm air or is the air cool.
Jan 29, 2010 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore 600 Dryer- suddenly stopped working
can you hear the motor running, if so then more than likely the belt broke, you need to unplug it ,remove the front cover, then top cover, then remove drum and you can start to restring the new belt
Oct 26, 2009 | Kenmore 600 7962 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 70 Series
hello,
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
jimorris77
