Please i need to know, how can i lock dialing zero for outside calls? Thank you in advance.
SOURCE: how to install the emergency numbers
Programme Code 309, code no. (1-5), emergency no., store,end or next.
SOURCE: phone got dial lock
Can anyone tell me how to open the dialing lock of panasonic integrated telephone system , for which the password is lost.
please waiting reply
Thanks
SOURCE: How to lock this phone
Okay. Here are the instructions to set an extension pin and lock. If you lose the pin, you will lock yourself out of the phone and it will cost you to get the instructions to clear it.
From your phone, dial *799 1 PIN # PIN # . The PIN is 4-10 characters and you repeat it. Now, to set it dial *771 on the intercom. Your set is now locked. To unlock, dial *770 PIN.
To erase your pin, dial *799 0 PIN.
If you lose your pin, the system manager will have to clear it. Also, if someone makes too many attempts to find your pin, it locks the set :-)
Good Luck.
Carl
SOURCE: I'm using Panasonic KX-T7730. and
In programming you can set up Forced account codes for Local, Toll, or All calls. The extension is flagged in program 605 or 2.1 of the system and the codes are put in 310 or 1.5. It's one of 2 ways you can do it, you can also change Class of Service on each phone to deny them access to certain numbers.
Keep in mind that this is programming for a TA-824 release 3.0. We know loop start CO lines and no ISDN or BRI. Your system may be different.
Carl
