SOURCE: need code for philips tv
you can get the codes from the link i have given you. Download the file and it has the codes and user manual for you there are quite a few for philips... so be patient and you will get it:)
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/ge/rm24912-manual.zip&area=other
A "fixya" rating would be great for my time to get this info for you.
thanx
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: remote codes
GE ........... 0704 0312 0018 0002 0502
................. 0006 0007 0601 0835 0901
................. 0114 0103 0803 0806 0310
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
SOURCE: Philips Universal Remote #CL034- Need tv codes.
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
let me know if this helps
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red
indicator stays on and release button
3: press and quickly release what
you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly
untill your t.v changes channels(up to 300 times) if you over shoot the
channel change press down til it changes again.
5: press and release
MUTE to install the code.
