Dishwashers Logo
Question about Beko Dishwashers
Beko dw 600 dishwasher, all programme lights stay on and it wont run or clear
All programme lights stay on, have tried switching power off and aslo holding programme button for three then seven seconds, but still showing all lights
  • Anonymous Jul 08, 2012
    programmtye has not run, there is no water in machine to empty?
Anonymous
I had this problem and followed the advice from Gallagher to no avail.
I sorted it as follows andd bear to mind I have never seen inside a dishwasher. I found the float valve and removed the connection to open circuit the switch, still the same, I then did the same to the sensor in the water container still the same. I concluded that the only thing left was the control module in the door.
I got the pcb on line for 22-00 and fitted it. job sorted
It says the changing of the module requires an expert, dont know why its a piece of cake.
Posted on Mar 08, 2013
5 Related Answers
Anonymous
  • 123 Answers
SOURCE: Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Posted on Jan 05, 2007
Anonymous
SOURCE: DISHWASHER- Model no: DW009
my dw009 is showing e2 does anyone know what it means ive tried everything
Posted on Dec 11, 2008
Anonymous
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Anonymous
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Can't start the dishwasher, lock button is lit up.
Hello Albert, On the Jenn-Air dishwasher you have, you have to hold down the "Heated Dry" button for 3-5 seconds to unlock the control panel.
This should unlock the controls so you can again use the dishwasher normally.
Since you''re likely going to have this dishwasher for some time, I've included a link where you can download a free owner's manual for it.
I would print out a copy for your future use and reference. I also have a file on my computer that I title "Home Appliances and Equipment" which is where I download and save an electronic copy so I always have a backup copy saved, since manuals aren't always readily available on the web, as the appliances get older.
http://www.jennair.com/assets/product/6_920374_A.PDF
The info on locking and unlocking the dishwasher can be found on page 13 of the manual.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
Testimonial: "Thanks for the detailed info about my question, VtToolMan, I greatly appreciate it. However, I tried to unlock it that way, but it didn't work. "
Light panel fully lit stopping program selection and start does a electronic part need replacing
I would suspect the user interface panel.
Most dishwashers can be tested thusly:
Turn off power to the dishwasher at the circuit breaker box. Take apart the Dishwasher door and unhook the cable from the User Interface panel to the main control board. Then, turn the power back on and close the dishwasher door so it latches. The drain pump should go on. If it doesn't the main board is bad. If it does, it's the user interface panel.
Cannot programme to anything but a cold wash
The computer switch needs replacing (start control)
I have a beko de 2762 fw dishwasher when i press start 3 out of the 4 lights come on and the moter continually runs.
It sounds like you have a leak. You need to take the dw out and lean in back untill the water will run outside.
Dec 16, 2013 • Dishwashers
2answers
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
2helpful
4answers
Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
1helpful
Water wont heat up
If your DW has an "energy saver" or "no-heat" button for wash or rinse, make sure it is not selected.  If that is not the case then the heating element is probably burned out and needs to be replaced.
Diswasher wont turn back on after being moved - DW Omega 908
Have you checked the door interlock switch to make sure it is not disabling the wash cycle?
Sep 01, 2008 • Dishwashers
Open Questions:
0answers
Beko dwd5410w Dishwasher E02 Error Hello, this is day two of trying to fix the dishwasher, so any help or advice would be gratefully received! The washing machine fills up with water at the bottom, then the E02 error comes on. After a short period of time, the machine then drains. The water isn't pumping around the machine or getting hot. So far I have tried: - Checking the drainage pump, was all clear. - Checking the water inlet pipe - it is high pressure I have a wet kitchen now - oops! and the filter going in is clear - Checking the drainage pipe - all clear and it is draining - Checking the bigger pipes going into the sump - all clear - Checking a smaller purple pipe going from the side of the washing machine to the sump - this was filled with fat. I used a chopstick to clear the fat as far as I could see as I don't think water could get through, but not sure where this pipe then goes or how to access it in case this is the problem. - Cleaning the fan arms - some gunk did come out here - Cleaning the normal filter though not where this drains, could only see a tiny hole and wasn't sure what to poke in it or if we needed to. Would be really grateful for any advice and tips on what to try next. It seems to be a problem either with heating the water or it is pumping around. I think E02 is normally a draining issue? But it seems to be draining okay... but not getting water into woosh around the machine.
Top Beko Dishwashers Experts
Marvin
Marvin
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
