Question about Kenwood Computers & Internet
Kenwood PS series DC power supply - maximum voltage issue
Hi, I bought a used Kenwood PS36-10 power supply (PS series). Specs: 0-36VDC, 0-10A. Additional info: For some odd reason, the model label is PS36-10Y2. The "Y2" has been added to label on the unit...it's even a different font. Problem: I cannot go beyond 20VDC. The Over Voltage Protection can be adjusted, but not beyond 23V (115%). What I have done so far: I do have the manual that even describes the DIP switch settings, but I cannot find any answers there on this issue. I have written to Texio/Kenwood...hopefully they give me something useful. I did open the unit, and it has a number of screw-adjustable resistors, but I did not touch any of them. Question: Any ideas from anyone with a similar unit (PS series)? Anyone with the schematics or the Service Manual? Thanks. --eric
Posted by ericg on
  • Kenwood Master
  • 18,856 Answers
First thing to do is check the unit with an external meter to see if the internal ones are accurate.
Posted on Mar 17, 2017
2answers
Hello. I have a Samsung 65" 4k TV ( UN65F9000). And have a no power issue or power issue. The screen got wonkey and then went black and now only clicking from PS Board. Removed back panel and...
First off 3.2 is the correct voltage for the PSON so we know the main board is sending the signal back to the power supply instructing it to come out of sleep mode and go to work, if your other power supply voltages are ok then you can rule out the power board. A gut feeling is you have a bad main board but its only a guess without doing some testing on the TV...you said you don't have sound, is that because you can't tell what input the set is on?...also have you tried the flashlight test?
1helpful
After programming irritrol auto watering system I push the function switch to run and it turns the watering time to off so nothing happens. Voltage at the 24 volt terminal is 13.2 volts, however when
The typical lousy power source for this system is likely defective. They will normally rise to 140-150% of nominal voltage (24V) and settle around the required voltage when loaded.
Check the supply (if separate) for a rating of voltage and current; for example: "24VDC/XXMa" where the 'XX' is the current that will either be in milliamperes or amperes.
To correctly measure the voltage, you must know first if it's output is AC or DC.
If this is a DC supply, it probably has a failed diode, if AC, the transformer is bad.
A less likely, but possible problem, is that the programmer itself has an internal failure and is overloading the supply.
If you have a meter with a separate 10A jack, and you can interrupt either side of the supply line, try measuring the load current.
This will however, only be possible if the 10A can measure both AC and DC or if you know that the supply output is DC.
2answers
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
No sound and no picture.Power comes on with red light changes to green. Replace caps (15) on power supply.
You need to check and see if all the control voltages (Power supply on) and DC output voltages are present. PS pin out: http://www.fspgroupusa.com/download/specs/FSP271-5F01_DIA.pdf
Please read my guide to see how LCD TV works.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
What is the DC external supply voltage for the Kenwood DPC-993?
It's used to power the player from an external power source - adapter, if you don't want to use the battery.
Hi team I have 230volts at input pl32 but on switch on . Fault may have been a power surge .Thank you for any help Ray Styles ALSO badged Goodmans and Kenwood. pvr 160gB twin tuner hdd recorder
have you checked i f the rectifiers -diodes are stopping the minus part of the ac current,making it a dc voltage,ther either 4 single diodes or 1 round one which has 4 legs you want to measure the terminal marked with a plus sign i think,this should be a smooth dc voltage of half the input ac voltage ,in this case around 115 vdc.,it may been a power surge have you the mains suppressent capacitor,s this usually there to take the surge of 240 mains supply ,supplied by your energy company.during busy usage,there is usually a power surge ie,during tv ads,ets. is there any input /output current/voltage,to the dc transformer or out of it,have you followed the voltage/current throug the power supply circuit.
1helpful
What is the proper DC power supply voltage for an
Power supply details are as follows:
Input voltage/frequency 100 Vac, 50/60 Hz (Japan)
120 Vac, 60 Hz (North America)
230 Vac, 50 Hz (Europe)
Output voltage/watt 12 V DC, 15 watt maximum
5helpful
Adapter specs
hi..
i've also got one without DC adapter... and looking around. find this link here: http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output 7.5v/1A
hope it helps
2helpful
3answers
Lost power adapter-help!
its 12V 1000Ma (1.0A) I work in radioshack... IN fact Im dealing with this problem as I speak... I need the Polarity for this however, otherwise theres a 50 50 chance this might get blown.
Computers & Internet Logo
Top Kenwood Computers & Internet Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Kenwood Computer and Internet Expert? Answer questions, earn points and help others
