Question about HP OfficeJet 7410 All-In-One InkJet Printer
Lines across scanned images
I have a blue, pink and yellow line running through images that are scanned with both the copier and scanner functions.  I have cleaned the glass and don't see any objects or scratches on the surface.  The lines first began with blue and pink, and have progressively worsened.  There are now 2 blue lines, 1 pink and 1 yellow line that always appear on the same place on the images.  These lines appear when I lay images on the glass as well as when I send them through the automatic feeder.  Any help is appreciated.
Posted by davissl2 on
  • 4 more comments
  • davissl2 Dec 09, 2008
    If you run the document through the automatic feeder or lay an 8.5x11 on the glass, the lines run from the top of the page to the bottom and the appear about 3/4ths the way over on the right. If I scan a 5x7, then the lines don't cross the image, but appear to the right of the scan. So, it seems the lines are in the same place each time. Thanks!
    Yes. The lines appear on the printed copies as well as images scanned into the computer.
    Not that I can see - I cleaned that surface as well as the glass.
  • Anonymous May 11, 2010
    is there anthing on the white surface opposite the glass? Even scratches?
    So if you scan the image to your computer are thelines in the scanned image file also?
    Are they horizontal or vertical lines?
3 Related Answers
Riztech
Mohammed Rizwan
  • 731 Answers
SOURCE: My scanner always scans with blurry lines across scanned images from it
I believe that you are trying to scan via HP solution center.
Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Try scanning.Please let me know after following the steps!
Posted on Feb 09, 2008
Anonymous
  • 14 Answers
SOURCE: Vertical lines when scanning using automatic document feeder...Glass is clean
It is not in the glass. More than likely it is in the rollers of the ADF feeder. If you open the cover of the ADF feeder you can see there are 3 screws (! is found under another small cover furthest to the back of the machine. Once these three screws are removed you can left the entire ADF feeder from the unit. You will then be able to clean all the rollers. Do not use alcohol as this will dry our your rollers and cause them to eventually crack. Just use soap and water to clean the rollers. Then reinstall the ADF feeder assembly back on the machine.
Posted on Nov 14, 2008
feelfemi009
femi john
  • 277 Answers
SOURCE: white lines across my scanned images
Step one: Reset the All-in-One
  1. Disconnect the USB cable from the product.
  2. Without turning the product off, unplug the power cord from the outlet.
  3. Wait 60 seconds, and then connect the power cord directly to a wall outlet. NOTE: Do not use any power strips, surge protectors, or extension cords. Power strips and surge protectors can limit the power supplied to the product, which can result in performance drawbacks.
  4. If the product does not turn on automatically, press the Power button (c00636182.gif ) to turn on the product.
  5. Reconnect the USB cable to the product, and then try scanning the original again. NOTE: To save ink, scan the original to a file on the computer instead of printing the scanned image.
  • If the scanner bulb does not light when the product scans the original, continue to 'Step five: Service the product.'
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clean the glass and scanner backing
  1. Press the Power button (c00636182.gif ) to turn off the product.
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord form the wall outlet, and then disconnect the power cord from the back of the product.
  4. Raise the scanner lid.
  5. Clean the glass by using a soft, lint-free cloth, moistened with a mild glass cleaner or water. CAUTION: Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride, which can damage the scanner glass. Do not spray the glass cleaner directly on the glass.
  6. Dry the glass with a dry, soft, lint-free cloth.
  7. Gently wipe the lid backing with a soft cloth or sponge, moistened with mild soap and warm water. Do not scrub the lid backing. CAUTION: Do not use paper-based wipes because they might scratch the backing.
  8. When the scanner backing is completely clean, dry it with a dry, soft, lint-free cloth.
  9. Reconnect the USB cable to the product.
  10. Reconnect the power cord to the back of the product, and then plug the power cord into the wall outlet.
  11. Press the Power button (c00636182.gif ) to turn on the product.
  12. Try scanning the original again. NOTE: To save ink, scan the original to a file on the computer instead of printing the scanned image.
Step three: Try a blank copy
  1. Load letter or A4 size, unused, plain white paper into the paper tray.
  2. Make sure that there is no paper or other document on the scanner glass.
  3. Follow one of these instructions to make a blank copy.
    • Press Start Copy Black on the product control panel to make a black-and-white copy.
    • Press Start Copy Color on the product control panel to make a color copy.
  4. If the blank copy does not contain vertical streaks, lines, or bands, try scanning
Posted on Jul 09, 2009
Ugly copies but clean prints
Prior to providing a final answer, one question...does it do the same thing whether you scan through either the document feeder OR the flatbed? Both options use the same scanner, BUT they view the scan through different viewpoints. The document scanner uses additional mirrors to get the image, and these mirrors tend to get dirty. The flatbed views the image directly through the glass. If it does the same thing through both flatbed or feeder, then a scanner firmware update might be in order?
May 30, 2014 | HP Laserjet CM2320nf All-In-One Color...
I am getting a blue line on my scans when utilizing the feeder
The feeder sends the original across a small piece of glass. The scanner stays in one position as the paper runs across it rather than the scanner moving and paper staying still. The little piece of glass is probably a 1/2 inch by 12 inch glass. just clean that strip of glass. use alcohol. there is probably some whiteout on the glass. It will appear as a dot. When the paper runs across it, the dot is run across the whole page causing the line. if you cant find the strip of glass, run a scan and try to see where the scan light sits while it's running. Clean everywhere where the light sits.
Jan 15, 2011 | Office Equipment & Supplies
There is a Black thick strip coming along while scanning what might be the problem
Something is stuck on your scanner "glass". This is a small strip of glass about an inch wide that runs from one side of the scanner to the other. If you open the panel where the documents are fed in to be scanned you should be able to see the glass. Sometimes a small flashlight comes in handy. Once you located the strip you can clean it with a cloth that has a bit of glass cleaner sprayed on it in the area you are using. Most of the time a general cleaning will take care of the line. If after cleaning the line does not go away then look at the image of the scanned document and use the original as a guide by placing it the same way in the machine that you placed it originally. The area of the document where the line is being created will guide you to where the area of the scanner glass is creating the line. Concentrate your cleaning effort in that area.
Good Luck and Thank You for using Fixya.
Oct 10, 2010 | Office Equipment & Supplies
Black line on image
It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
Nov 08, 2009 | Canon DR-2050C Path-Through Scanner
Lines when scanned
The common solution on this sight to this problem on any copier seemed to be simply clean the glass. I first cleaned the glass on the bed...no help. Then I lifted the feeder and discovered a portion of the glass under that as well. Once it was cleaned the lines disappeared!
I saved $$ on a useless service call for a simple, easy to fix problem thanks to this site!
May 22, 2008 | Canon ImageClass MF5770 Laser Copier...
Scanner Imaging problem
Your scanner’s lock switch may be locking up the carriage unit. Depending on the model you own, your scanner’s lock switch resides in one of two locations. You can find it beneath the scanner itself or in a corner next to the scanner bed after you lift the lid. The switch should be marked with a locked and unlocked padlock symbol; slide the switch to the unlocked padlock to unlock the carriage unit.
It’s also possible that the supplied USB cable is improperly connected to your computer. Connect the cable directly to your PC. Canon’s online documentation indicates that scanners that connect via a USB hub may not work properly. Once you have unlocked your scanner and properly connected it directly to your computer, try to rescan the image.
Mar 01, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Vertical lines through scanned images.
You should clean the small glass under the top lid. Chances are there is some white out or ink or mark on the glass. Look carefully because usually it is just a small dot>
Dec 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Yellow line showing on in scanned pages
if you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
bye
Nov 14, 2007 | HP 9200C Digital Sender
HP OfficeJet 7410 All-In-One InkJet Printer Logo
178 people viewed this question
Ekse
efs_perpends
efs_perpends
