Question about Toshiba 42H81 42" Rear Projection Television
No picture no sound
Red power light comes on but no picture or sound. All cables etc. appear fine.
Posted by aquar4321 on
TEXAS TV PARTS
    New Friend:
  • 22 Answers
go to ebay and search for TEXAS TV PARTS or texasgreatdeals4you.
then Ask this guy to fix your board,he will tell you which board to send to them.
alright.
Posted on Jul 07, 2012
No picture no sound, red light on, left unplugged over-nite, no change. Turn on/off a number of times, got back perfect picture/sound. Turn off, same problem, no picture/sound, red light on. Tried...
First if the model number is right here: When the red light is on about 80% of the set inside is powered up and running all out.
On these sets if you turn it off and the red light does not go out one of the relays on the power board is engaged or stuck in the closed position.
If I remember this model it has three black rectangular plastic relays on the power supply board(follow power cord into the set to see if this is the case.)
Relays have voltage and type marked on top (like 12 vdc etc).
Carefully with back removed what I would do is with something NOT metal tap on each relay until (with set turned off) the red light goes out.
That is the bad relay----if set has 3 I usually replace all as only 4 solder connections each and they are not real expensive.
I saw one of these sets where the customer had been gone for a month and when she returned set appeared to be off but Red light for power was on.
The set was so hot I tapped on the relays and then when I knew which was bad shut the set off and unplugged it to let it cool off.
I am saying if you leave the set plugged in and the red light is on There is the chance it may overheat to the point where you could have a fire.
Let me know if you have questions.
SD TECH
Sep 26, 2011 | Hitachi 53FDX01B 53" Rear Projection...
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Sony kv-35s42 35" tv picture blinks off and on
my best advice would be to check power supply for faults, bad capcitors etc to r/o the possiabilies of a power failure.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | Sony KV-35S42 35" TV
MODEL HLC 22 R TV/DVD COMBO
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires.Switch input mode Vitally
Mar 26, 2009 | Haier HLC19R 19 in. LCD TV/DVD Combo
Sound but no picture
Its the same problem as the 3 red lights. We can fix this for you. email if intersted in estimate
[email protected]
Dec 23, 2008 | Microsoft Xbox 360 Console
No picture or sound on my tv when hooking up my av cables
Ok
switch the power switch on then wait til the red light comes on..
the push and hold the power button until you hear it beep it should reset itself and sync up! may take 5-10 times
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung HCL4715W will not power on
At five years old, I doubt it will be worth replacing the power supply , a picture tube or two and possible the signal board. Cut your loses and get a new set.
Aug 25, 2007 | Samsung HCL4715W 47" Rear Projection...
After i power it on, there is no pictures, no sounds too.
Does the red light come on? Do you hear a relay click, Have you unplugged and plugged the set back in? Short of opening the set up you probably have a power supply/deflection issue and will require a tv technician.
Jul 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
