Can it easily be replaced?
SOURCE: No picture Panasonic PT-40LC12 40
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find. Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Posted on Jan 28, 2008
SOURCE: PT-40LC12 fuse problem
Sent me the serial number, and I can check for any re-call ...
my e-mail is <[email protected]>
Posted on May 22, 2008
SOURCE: lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Posted on May 28, 2008
SOURCE: Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Posted on Jul 07, 2009
Apr 14, 2011 | Panasonic PT-40LC12 40" Rear Projection...
Jan 20, 2010 | Panasonic PT-40LC12 40" Rear Projection...
Dec 08, 2009 | Panasonic PT-40LC12 40 in. LCD Television
Oct 12, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Jul 09, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Mar 19, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Nov 13, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Oct 24, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Aug 01, 2017 | Panasonic PT-40LC12 40" Rear Projection...
May 29, 2011 | Panasonic PT-40LC12 40" Rear Projection...
23 people viewed this question
