Freezer working fine, the fridge part stopped working after a power cut
SOURCE: Freezer problems
remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
SOURCE: smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
SOURCE: Smeg Fab 32 door problem
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
SOURCE: My Smeg S28 has stopped after a power cut last
your unit may have experienced a power surge as a result of the power out ask your nabours if they have any electronics in there homes that are not working if so the electricity provider you go with must under law pay for the repair in any case it sounds like in 99 % of cases were power goes out and comes back on with a unit no longer working the power strkie is to balme have the power board tested for damage
best of luck
please remember to rank my reply
Testimonial: "trying EDF now......"
SOURCE: Smeg CR330SE fridge/freezer hi there fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
