1999 Ford Taurus Logo
Anonymous Posted on Dec 08, 2008
No sound i installed a aftermarket radio in my 99 ford taurus and have no sound no please help asap
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Jan 02, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
Helped
8716
Points
32
I just installed an aftermarket radio in a 93 mustang and I had to hook up the blue wire for the power amp to work. I am not an expert just passing on what fixed my problem. Good luck
1999 Ford Taurus stereo wiring diagram
These are the three top websites. According to Just Answer it came with AM/FM Radio, AM/FM Radio Cassette, and two types of AM/FM Cassette / CD Changer. All 4 are shown in the link
https://www.justanswer.com/ford/0hkix-find-1999-ford-taurus-stereo-wiring-harness-diagram.html
These are the other two websites.
1999 Ford Taurus Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
1999 Ford Taurus Stereo Wiring ; Ground, Black/Light Green ; Illumination, Light Blue/Red ; Dimmer, n/a ; Antenna, Left Rear ; Front Speakers, 5" x 7" Doors.
1999 Ford Taurus Radio Wiring Diagram
MODIFIEDLIFE https://www.modifiedlife.com > 1999-ford-taurus-radi...
Our 1999 Ford Taurus radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 1999 Ford Taurus Radio Wiring Diagram; 1999 ...
.. Here is the AM/FM Radio wiring
1helpful
Does anyone know if a 6cd radio from a 2007 Tahoe can be installed in a 2009 Ford Crown Victoria? If so please post instructions on how to do it. Thanks in advance
No. This would be difficult at best. The Tahoe uses a class 2 data bus of which the Radio is a part of and that is why they require an expensive aftermarket harness to replace the factory radio. If you are adamant about trying you would need a Tahoe harness that plugs into the radio and a crown video harness that plugs into the car. Both may be available from metra at metraonline.com. you then would need to figure out a way to re create the digital data bus signal that tells the radio to turn on (GM vehicles have not had a traditional radio turn on lead since around 19 99 - depending on specific car models) . It would be cheaper to purchase an aftermarket radio for the crown vic.
2003 ford taurus installed aftermarket cd player in my car and accidentally grounded the poet wire out and now I have no power windows, no wiper blades, no radio, no speedometer, odometer, or hazzard...
dont b a **** fool and cut wires under your dash for some boom booms in your car buy the connecting harness they sell theres one for every make and model out there solves guessing and saves headaches... dont be a ******* buy the right parts
We put a aftermarket radio in a 98 turaus with a install kit and now the heater dosnt work any more
Pull the radio and check the harness on the heater controls, probably just knocked the plug loose.
2000 Ford Taurus - Installed a new radio and used the Meta 99-5716 install kit with wiring harness. After install, radio, pwr windows, pwr locks, dome light, windshield wipers, and speedomoter have stopped...
Sounds like you have blown fuses which could have happened if you accidently short circuted something while wiring up the new stereo. Check your fuses to see if any of them are blown.
1helpful
What is the tool called that i need to remove the radio, in order to install an aftermarket deck?
It is a ford stereo removal tool kit, most tool trucks have thease otherwise the dealer will have one, if you catch the right dealer they may let you use one for a few minutes to remove it.
I hope this helps. please help me by leaving feedback, good luck
1999 ford taurus speaker wires color code
the speaker wires are the same color at the rear control module as they are at the head unit
are you trying to replace the "football" type radio?
if so...what you are actually replacing is the "remote" for the rear control unit.
See the place you bought the radio from for a "special" kit to install an aftermarket radio on this system
I have a '99 Ford Taurus with a cassette and 6 changer cd player. The radio works for a while then cuts out, then comes back on. It can play for a few hours or a few days. I recently bought another radio...
yes i agree it sounds like it is overheating. Just pull back the carpet in the trunk on the left hand side. Check all the connections make sure its got a good ground etc.
This unit is where all the power etc comes from for the headunit and speakers.
I need to know how to remove the stock radio from a 2003 ford taurus so i can install an ipod adaptor
Ebay has the tool for removal cost $1 plus shipping. this tool is for the 2 holes on left and right side of radio face fit tool in then push alittle out worad and pull. Follow aftermarket instructon on install.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
