1999 GMC Suburban Logo
Anonymous Posted on Dec 08, 2008
Need sterio wiring diagram for 1997 1500 gmc p/u ,factory harness
Trying to change factory sterio, need to find color codes for factory harness, to be able to install aftermarket name brand sterio,for 1997 1500 serious extended cab 4x4 gmc seirra pls help, pls send to
[email protected] if you can help, also have 1993 blazer with same problem . thanxs
  • Anonymous Dec 08, 2008
    went to canadian tire and got the adaptor, but after i installed it i was left with 4 extra wires, and the sterio would not turn on
Anonymous
Level 3:
  • Master 507 Answers
  • Posted on Dec 08, 2008
Anonymous
Master
Level 3:
Answers
507
Questions
Helped
212348
Points
1493
DON'T REMOVE FACTRORY CONNECTORS!!!!!!!!!!!!!! Spend $15 and buy a wiring kit. It plugs right into your vechile wires and the kit tells you what wires are what. Splicing the wires will lead to headaces down the road!!!
Replacing rav4 factorie sterio 2004 with a new 2015 jvc sterio system
Use a harness adapter if you haven't cut the factory wiring plug in the car. If you have go to www.modifiedlife.com. they have an excellent resource page with wiring diagrams
Stereo wireing diagram needed
If you are putting in a after market sterio,you need to go to autozone or walmart and get a sterio plug that plugs into your factory plug and the wiring diagram will be with your new plug that you bought,real easy!!
03 ford expedition audio wiring diagram
sounds like a faulty instrument cluster
Wiring diagram 2001 gmc seara 1500 sl
I am sorry but Fixya has no wiring diagrams. The diagrams are part of the factory repair manuals and these can't be shared due to copyright laws.
1helpful
I want to install an aftermarket stereo in my 06 GMC Sierra. Do you have the wiring diagram for the factory stereo harness?
go to walmart or bestbuy and get the wiring adapter so you dont have to cut any wires. they are color coded
3helpful
2answers
Replace factory radio on 2002 yukon xl
all you gotta do is carfully pry the dash panel off (prying from the far left end is easiest) completely remove panel. then there are 2 clips that hold the factory sterio in place. push on the both clips while pulling the radio out. simply disconnect the wiring harness from the back of the radio. using an adapter avaliable at your local radio shop (scosche p/n gm02, mdarb and gm1483b) wiring harness, dash install kit, and antenna adapter. then simply match the colors on the new radio's harness to the adapter harness, crimping each connection with a "but plug". then simply follow the instructions included with the dash install kit to assemble the kit.connect the antenna adapter to radio, plug in all cables. test to see if everything works properly before the final install. install sterio into dash install kit, re installing kit where origional radio was. then simply put the panel back in its place by firmly pushing on it untill it snaps into place. then enjoy your new radio!
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
