Question about Logitech Cordless Desktop MX 5000 Laser
Utility cd for dell wireless keyboard #820001438
My dell wireless keyboard doesn't work the mouse works
First try checking and testing the batteries in the keyboard to see if they are good and working, if they are fine then try reinstalling the Bluetooth software using the CD that you acquired with your wireless devices. Then if that doesn't fix the problem then check if the adapters are configured well and also if the keyboard is in range. if it still doesn't work read the instructions perhaps something is missing.
Mar 18, 2011 | Dell Wireless Keyboard Optical Mouse w0147
My laptop touchpad button not working
most likely, it already needs a replacement, but do try to uninstall and reinstall your touchpad driver and make sure your touchpad settings are correctly configured. you can also try to use the drivers and utilities CD from dell to run a test on the touchpad to see if they will respond to determine if it is a hardware level
Mar 12, 2011 | Dell XPS M2010 Wireless Bluetooth Keyboard
How do I reprogram my Dell wireless keyboard button for mail from Outlook to Thunderbird?
Windows offers a download utility call Tweak UI where you can program hotkeys to open any program you want. I set my media button to open Zune.
Feb 21, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Wireless wont enable on my dell inspiron 6400 win7
if you cant connect to any network because your wireless is not turned on, try this press and hold the " fn " key in your keyboard and tap f3.
you will able to see the wireless light is turned on. you can also check the device manager and look under the network adapter if the driver is properly installed or if it has a symbol of " ! " or " x ". if that is so then try to install the driver for wireless adapter using the "driver and utilities" cd.
(note: the fn key is usually next to the windows key)
i hope this helps.
Feb 20, 2010 | Dell Inspiron 6400 Notebook
My Dell monitor blacked out. It has a wireless keyboard.
I would go to the manufacture's website and download the driver and at least rule that out as the problem.
Sep 09, 2009 | Dell Wireless Keyboard Optical Mouse w0147
I have a wireless keyboard and mouse. I do not have the CD
If you have Windows XP or later you can just plug the wireless receiver and let XP find it and install automatically. You may have to reboot to get it installed completely. Alternatively, if you have internet access you can go to the home site for the keyboard and mouse and download the installation.
Jul 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
How do you install dell wireless mouse and wireless keyboard?
You should have got a install CD with the wireless keyboard and mouse, just pop the disk in the drive, run it and install the drivers, then connect the receiver to a USB port and let the system install the drivers, to connect them and make them work look for a small button under the keyboard and mouse and press them to connect.
Good luck
Jun 28, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless keyboard not working
What o/s are you using? If Vista(and your mouse works) you can access the onscreen keyboard to log into your computer and access the utility to reconnect your keyboard.
Jan 23, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell inspiron 6400 keyboard is not working
Do you still have the dell diagnostics cd and the drivers and utilities disk, you can press f12 and boot to the cd and then run the diagnostics, if not its either your cable is not connected anymore and you need to reseat the cable, you can follow these instructions http://support.dell.com/support/edocs/systems/ins6400/en/sm/keyboard.htm#wp1111863 or http://tinyurl.com/fq6m5 if after reseatting the keyboard and still it wont work then you need to purchase a keyboard for your system.
Oct 31, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Dell wireless mouse and keyboard installation problem
click start
right click my computer
properties
hardware
device manager
?mouse and keyboard
scan for hardware changes
Aug 23, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Logitech Cordless Desktop MX 5000 Laser Logo
59 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Alun Cox
Robert Stout
Robert Stout
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
