Philips 32PT5441/37 32" TV Logo
Posted on Jul 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forget the parental lock cord so i need to reset and autoprogram the tv
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Jul 07, 2012
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004767
Points
237762
1. Select Change PIN in the Features menu.
2. Press the cursor right to enter the overriding PIN code 0-7-1-1. 3. Enter a new personal 4-digit PIN code.The previous code is erased
an the new PIN-code is stored.
2 Related Answers
Anonymous
  • Posted on Nov 28, 2007
SOURCE: how to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
A
Anonymous
  • Posted on Oct 06, 2008
SOURCE: How to disable parental lock
Go in and reset the code.
9helpful
6answers
Hisense H32V77C password reset
Thanks Tj the 0532 code works very well no matter the password
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 • Televison & Video
tip
Toshiba 50HP95 VChip Reset
Toshiba 50HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Parental V-Chip parental lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
1helpful
Need to reset parental locks .tv is locked out
HELLO If you forget your ACCESS CODE NUMBER, use the factory code 7777 to erase your key number. This will
reset the access code number back to the factory pr eset (0000).
shaun
1helpful
Sylvania TV parental lock set by child
V-Chip info
Your personal access code will be erased and return to the default (0000) when a power failure occurs or when you turn off the power using a wall switch. If you forget the code, unplug the power cord for 10 seconds to restore the access code to 0000
tip
I hope that helps.
tip
I hope that helps.
6helpful
2answers
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Parental controls
If you forget your password, press and hold TV on the remote and the
MENU button on the television simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
