Televison & Video Logo
Tina Slocum Posted on Jul 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't get the tv to switch from cable to antenna mode using a RadioShack remote or the buttons on tv
Level 3:
Top Expert:
  • Zenith Master 76,851 Answers
  • Posted on Jul 07, 2012
Zenith Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003927
Points
237762
It sounds that the front panel controls are locked with your tV. You have to unlock it first, if you want to change its input selections. If you cannot select the inputs by using the remote control [I thing you are using a universal remote control], setup the remote control with an other setup code. All codes to remote control won't work with some functions. You have to search and select, which code give maximum functionality with your TV.
2 Related Answers
Anonymous
  • 3130 Answers
  • Posted on May 12, 2006
SOURCE: tv won't get channels
We have the owners manual in case you misplaced yours . All ya gotta doi to get it is to click on the zenith B32A34Z model # At the top of this page and scroll down to the manual. Now according to the manual in the menu there is an antenns /cable setting and its in the EZ progrom mode. look at the manual as I dont remeber 100% but its there. It sounds like you or someone switched it when they were in the menu. Good Luck
Anonymous
  • Posted on Jan 26, 2009
SOURCE: How to change from video mode to cable/Antenna Input without a Remote
Use the menu option on the tvs front control panel. This should allow access to your video sources.
2helpful
2answers
How do I change from cable to antenna?
Without knowing the make and model it is difficult to answer your question accurately. In general you would change either the source or input option. Usually the antenna option is called TV.
2answers
How do I switch the TV from cable to regular TV
Depending on your TV make, normally hitting the antenna button will switch you from cable to antenna (regular) TV.
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
My Vizio, when I turn it on the Vizio turns white, but the screen is black and there is no sound coming through
Have you tried hitting the 'input' button on the remote control?
Check the connections of external devices like an antenna, satellite, or cable that may be connected to the TV.
Press the TV button on the top of the remote to return to the TV mode if you have changed modes.
Can't connect to the TV. How do I do this?
In the UK (and some other countries) you will need a SCART to SCART cable. Simply plug it into appropriate sockets on rear of TV & DVD player.
Elsewhere you will need a 3 plug RCA (phono) cable. Plug into colour coded sockets on both sets.
Use TV remote 'mode' button to switch from TV antenna signal source to RGB or other source as appropriate
2answers
I hook my antenna to the back and I'm not receiving a picture
I'm assuming your Antenna is connected to your TV with a co-axial cable? If so, please make sure you have run the Analogue/Antenna/Air channel scan correctly:
1. Switch the TV on
2. Press the "MENU" button on the Curtis remote supplied with the TV.
3. Press the RIGHT arrow button five times to highlight the "Channel" menu
4. Press the "ENTER" button or the DOWN arrow once to open the "Channel" menu
The Air/Cable option should be highlighted.
5. Use the LEFT/RIGHT arrow buttons to set the "Air/Cable" option to "Air"
6. Press the DOWN arrow to highlight "Auto Scan"
7. Press the "ENTER" button or the RIGHT arrow once to start the automatic channel scan.
When the scan has finished, the TV should automatically return to viewing mode. If not, just press the "EXIT" or "MENU" button on the remote to close the menu.
You also need to make sure the correct INPUT/SOURCE is selected on the TV:
1. Press the "SOURCE" button on the Curtis remote
2. Use the UP/DOWN arrows to highlight "TV" in the INPUT SOURCE menu
3. Press the "ENTER" button on the remote to select "TV" and close the INPUT SOURCE menu.
This should be all you need to do to watch your TV from an antenna source.
Please post back if you are still unable to get it to work and need further assistance.
Regards,
BElectric
Initial setup - I have Dish, is this cable or antenna? I selected antenna & now all I can get is "scanning channels". Also, I can't get back to select cable. How can I start over as if I...
Hello Susan,
I'm very sorry, my internet disconnected in mid-chat. To get back to set-up and select cable, please do the following:
1. Turn the TV off
2. Turn the TV back on
3. Press the "menu" button on the remote
4. Use the Down arrow on the remote to highlight the "TV" option - the third option down.
5. Press the "OK" button on the remote
You will now see options for "Tuner Mode", "Channel Scan" and "Channel skip" Make sure the orange box is encircling the "Tuner Mode" option (if not use the up/down arrows to select it) and then press the right or left arrow until it says "Cable" on the right hand side.
6. Press the down arrow to highlight "Channel Scan"
7. Press "OK" on the remote to start the scan.
When the scan is complete, the TV should revert to watching mode, if not, press the "Menu" button on the remote to exit the menu.
Once again, I apologise for losing the chat session. I hope the instructions above solve your problem.
Please let me know what happens, by replying to this message and I will assist you further if necessary.
Regards,
BElectric
How to switch sharp tv lc26d4u from air to cable using remote ga263wjsa My mother touched the a- antenna button and now it's in air mode.can't switch back to cable .no button?
Press a button on the remote that said tv Menu.Goto SETUP,go down to CH.press the CH. highlight.Pick CABLE and press enter than tv will automatically scan ur tv for ur pay cable channels.
1helpful
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
3answers
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
