OPERATING INSTRUCTION MANUAL
Samsung has the manual you want is the 1.75 MB PDF at the bottom of the list here: http://www.samsung.com/uk/support/model/C61R2AEE/XEU-downloads . If this second link doesn't work, follow the directions below to reach this page.
Samsung has the User's Guide for the oven on the Support tab, see http://www.samsung.com/uk/consumer/home-appliances/cooker-hobs/ceramic/C61R2AEE/XEU
. The support tab is on the right. The manual for the cooking hob can
be accessed from the Need More Downloads link below the Download button.
I hope this helps.
SOURCE: Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
SOURCE: have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
SOURCE: Stoves 700CTH hob
I have a Stoves 900 CTH with the same problem. Its been like it for about 6 months and we're still able to get it going eventually.
If you turn the power on at the mains and leave it beeping for about 2 hrs then press the power on touch button. You should see all the "0."s flashing. When the flashing and beeping goes slow try pressing one of the hob buttons alot until the little dot illuminates next to the 0 then quickly lit the + button.
It sometimes works after 5 mins but other times it takes 20-30mins and is a real pain in the ****.
I did ring Stoves a while back and they quoted me £190 for the pcb but I hardly use it so just lived with it as it is but I finally had enough tonight and done a web search which turned up this thread.
I've just pulled it to bits to see if I could locate this "C17" but not 100% sure what I'm looking for.
Is it the big silver thing in the center with 5B RVJ on it?
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
