The product manual does not have instructions on how to get the remote to control the TV. I have codes, just not the procedure to activate it.
SOURCE: I need to find out how to program my samsung RS-105N remote control.
The picture you have is a Directv universal remote.If that is correct.
Turn your Tv on.
Press and hold the TV and SET button until the TV button lights up. 4 seconds or so.
Release the buttons.enter one of the 3 codes below.If the TV turns Off you have the right code,press the TV button to lock the code in.repeat if the code does not turn the TV off
for Panasonic the codes are 034 or 080,056, 164
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
SOURCE: remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
