SOURCE: Dell Vostro 1310 - when turned on screen still
it may be bios problem or loose connection with Hard disc...
So, follow the below steps:
1.remove the battery and power adapter
2.press the power on button 2 minutes
3.replace the battery
4.now on the laptop normally...
now see the result....
if not solved then follow the below steps
2.remove the hard disc,cd/dvd drive
5.if any display appears then problem with ur hard disc or cd/dvd drive.
follow the below steps to check the problem with your hard disc or cd/dvd drive
6.connect the cd/dvd drive
5.if any display appears then the cd/dvd drove has no problem,then problem with ur hard disc drive.
SOURCE: The lock sign with a 9, flickers when i start
There are 3 LED lights that are used for Diagnostics. Here is a link to your laptop's manual: http://support.dell.com/support/edocs/systems/vos1310/en/SM/html/trouble.htm#wp1092170
