SOURCE: Compaq Armada E500 - Increase Memory
Try one only 256 it should work now. You cannot use a 256 with a 64 it just will not work it is physically impossible. I know with some of those older models and Im picking yours is because you mention you were using 2x64. What you should have done was to buy two x 128 I am possitive your board can only handle 256mb of ram. Try the one only and if it works use that I dont think two of them will work not on that board?? Let me know ok. You might wanna clean your machine out with a software like this and its 30 days trial but has all features till it expires: http://www.tuneup.com. else if you dont want to take my advice on your laptop you can always go here: http://www.compaq.com
SOURCE: compaq armada e500
The key for bios is F10 just press during compag loading screen or if dat doesnt work immeditely after. I found this out by trying all of them in sequence to see which one worked
SOURCE: When I turn my Compaq laptop on the lighting bolt
Hi There
I do have one sugestion have you checked the ram of youre laptop?
its normaly the ram that causes this problem
Hope this helps
SlitWrists
SOURCE: Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
SOURCE: my compaq 615 does not
What you are seeing is a "blink code". Similar to something like a digital SOS message, your laptop is built to flash certain LED lights a specific number times to indicate a hardware problem.
According to Compaq's table of blink codes, the Caps Lock LED light blinking five times consecutively means you have a system board failure. If your laptop is still under warranty, I would contact the company immediately and have it shipped out to be serviced. Otherwise, you will need to either pay Compaq or another third-party repair shop to fix or, more likely, replace the system board.
