Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
First think , has it been dropped, jarred, banged, .....you get the idea? Does it continue to blink, the HDD? Do you see a "ghost image" in the monitor in a bright light? Do you here sounds? You say "nothing else happens", meaning the light stops blinking? Shut down, unplug, remove battery, plug in, try to boot noemally.
Someone needs to open it to SEE what is happening--if the unit holds more than one disc (model seems to indicate that) you likely have a mechanism problem with something jammed or even broken--mechanism could also be out of alignment which is a task for a pro.
Look and see what is happening is first thing needed here.
Check its power regulator section and Line Output Transformer. The work is a skilled one, and only an expereinced service technician can go for ward. You must have its repair book with you too.
a 42hp66 is a plasma set,, the y-sus or the z-sus circuit board has probably gone bad.. as these are expensive parts you might want to have a technician determine which one of the two is bad before ordering both of them
