With power-steering it could be one of three problems. 1- power steering pump could be going out ( normally with the pump the car will whine but will not normally leak and still hold fluid) 2- a leak in your power steering lines ( and can normally be resolved with new lines or sometimes you may be able to bypass and clamp the leak on the line) 3- you may have busted the O rings in your powersteering pump and that will actually cause the pump to leak
hint- alot of people will tell you that you may also use transmission fluid for power-steering this is true you can its that same thing as power-steering fluid just a different color (but dont put power-steering fluid in a transmission, but at the same time if you plan on replacing the pump i would use transmission fluid due to it being cheaper but it will cause the O rings in the power-steering pump to go out quicker to cause a worse leak) so i would recommend to locate the leak first before using trans fluid due to if its in a line you wont have to replace the pump but if its already the pump this is the cheapest fix until repaired
