Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Billy Walton Posted on Jul 05, 2012
I have a 150 Mercury on a Cobra Boat its making a beeping sound when I try to crank it up or when i turn the key over to crank it.
Beeping sound when the key is turn on
x1745
Level 1:
  • Contributor 40 Answers
  • Posted on Nov 13, 2013
x1745
Contributor
Level 1:
Answers
40
Questions
Helped
34764
Points
78
There are two types of warning horns to alert the operator of an
active problem within the engine's operating system.
1. Continuous six second beep: Indicates a critical engine
condition. Depending on the condition, the Engine Guardian
System may engage and protect the engine by limiting its
power. You should return to port immediately and contact
your servicing dealer.
2. Intermittent short beeps for six seconds: Indicates a
noncritical engine condition. This condition does not require
immediate attention. You may continue using your boat,
however, depending on the nature of the problem, the
engine's power may be limited by the Engine Guardian
System (see Engine Guardian System following) to protect
the engine. You should contact your servicing dealer at your
earliest convenience.
FEATURES AND CONTROLS
eng 63
It is important to note that in either of the above scenarios, the
horn will only sound one time. If you key the engine off and
restart it, the horn will sound again, one time, if the fault is still
present. For visual display of the specific engine functions and
additional engine data, refer to SmartCraft Product information,
following.
The operator is able to correct a couple engine problems
indicated by the warning horn. These conditions are as follows:
• Cooling system (water pressure or engine temperature)
problem. The warning horn will sound Intermittent short
beeps for six seconds. Stop the engine and check the water
intake holes in the gearcase for obstruction.
• Low oil pressure problem. The warning horn will sound a
continuous six second beep. Stop the engine and check for
low engine oil level. Refer to Fuel and Oil - Checking and
Adding Engine Oil.
ENGINE GUARDIAN SYSTEM
The Engine Guardian System monitors the critical sensors on
the engine for any early indications of problems. Engine
Guardian is functional whenever your engine is operating, so you never have to be concerned about whether or not you are
protected. The system will respond to a problem by sounding the warning horn for six seconds and/or reducing engine power in order to provide engine protection.
If the Guardian System has been activated, reduce throttle
speed. The problem will need to be identified and corrected, if
possible. The system must be reset before the engine will
operate at higher speeds. Moving the throttle lever back to the
idle position will reset the system.
Mercury 150hp Optimax outboard
many mercury motors use a rubber mounted prop on the shaft which is a sacrificial idea to prevent gear box damage and prop damage in with under water objects
what you suggests indicates that at certain load situations that rubber has failed and allowing the shaft to turn but is not driving the prop as required
It is driving just enough to give you steerage to get home
Sep 01, 2018 • Boating
What size fuel tank is in a 1996 Cobra Culprit bass boat w/150 jojmson faststrike?
Is it a removable fueltank? Then it should be 22litres.
Otherwise, there should be a sticker with the fuel tank data near the filler connection or the fuel gauge...
I have a 2006 Mercury Mountaineer . I was driving and all dashboard lights came on and made a beeping sound so I turned it off and It will not start. Is this a major fix? Computer switched twice.
Who switched the computer ? Where they programmed ? All dash board lights came on because vehicle engine stopped running ! Will not start how ? When you turn the ignition key to start position does any thing happen ? What I'm getting at here is it a no crank - no start or a engine cranks - no start . Big difference in diagnostic trouble shooting . As far as how much it would cost and is it a major fix ,nobody can say for sure .
1helpful
2answers
Suzuki4stroke 150 hp will not start, new battery gets juice just clicks
starter solinoide sounds like it failed if its clicking ! remove engine cover and as a friend cranks the key listen where the click is and it will have the +wire from battery and then a wire to starter , check connections are tight and if all ok then replace solinoide !
Why won't my Mercury Optimax 150 outboard start up. Engine turns over just fine, and there's 2 beeps to the throttle box.
I usually do cars and trucks, but if you are getting an electronic beep, you might go online and refer to an engine Manual for what you own. You may have a low oil lockout for the crankcase on a 4 cycle or a low oil cutoff alert for a 2 cycle with an automatic oil feed mixer. Some transition of inboard-outboard technology to outboards can include tilt lockout so that you can not start up in gear. Most prevent the starter from turning, but could keep the engine from firing if they want to wire it that way. With the "beeps" it would seem to be a Code.
COBRA 150 WILL NOT TRANSMENT
forgetting to turn it on. making sure its in CB not PA mode.turn squelch all the way to left and rf gain to the right
89 150 HP mercury has no spark
Hello Wendy,
Check The Kill Switch Is In on The Control Box,
1helpful
I have a 90 Horse power Mercury outboard Boat motor on a skeeter boat and the startes cylinoid is just making a clicking sound but the motor won't start . Do you think it could be the starter?
Sounds like the starter. Check if you have power at the solenoid from the battery with just the power on (key turned on, power switch on.) thats good-- you have power-- if not you have a wiring problem from your battery or main switch.
Otherwise you have a starter problem probably.
May 14, 2009 • Boating
Top Light Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
john h
Are you a Light Boating Expert? Answer questions, earn points and help others
