Question about Samsung DynaFlat TX-P3064W 30" TV
My 30 inch samsung dynaflat tv won't turn on
It has power and clicks like it is going to turn on but nothing...it is like it kicks on and kicks right back off
Posted by faeriedre42 on
4 Related Answers
Anonymous
  • 35 Answers
SOURCE: Samsung DynaFlat TX-P2775H 27
Do you get any indication of power to the unit? Mine didn't.. the light next to the power button didn't come on. Turned out it was just a fuse inside the unit. So, take it in for repair and hopefully its a simple fix.
Posted on Dec 13, 2007
Anonymous
  • 934 Answers
SOURCE: 2003 32 inch samsung dynaflat hdtv
Dez,
The ticking indicates a feed back on the power supply - most likely the shutdown circuit itself because something up-circuit is shorted. MY first guess would be the HOT (Horizontal Output Transistor) - Second guess the FBT or Flyback Transformer...
I might have the service manual for that, just email me personally and make it clear what you're after. I get nearly 3000 emails a day and I be real lucky to remember what this is all about when I get the mail...
Bill
[email protected]
PS Go online and download Pando... It's a free download and the best way to send large and/or multiple large files over the net...
Posted on Feb 03, 2008
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Samsung TXG2547 25"inches TV problem
you have damage your tv micro chip, regulator ,or horizontal output with static current when you plug out your tv from th plug,what is clicking is the relay trying to power up your tyv but due too the damage it cannot power have a tech repair your tv good luck
Posted on Oct 28, 2008
Anonymous
  • 261 Answers
SOURCE: TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Posted on Jun 29, 2009
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
1helpful
2answers
Good morning, I have the Hyundai hp4200 which will not turn on, when you switch on it clicks then 2 minutes later clicks again to onto I guess standbye. However, if you turn it on and off by the socket...
Yep, I can help but I am afraid that I won't be able to bring totally good news.
The TV is in forced standby also called "protection". Protection kicks in when an internal fault such as a short (big power draw) or a wrong voltage is detected. The click comes from a relay activated by the protection circuit to force TV to shut down.
All you can do is disconnecting the power cord, checking if there is a fuse built in the power cord, replacing fuse and connecting back after about 30 minutes (that allows power drain). If the TV does not work there are faulty internal parts that need replacement.
If now the TV does not start at all, and not even the standby light is on, then the problem is usually the PSU. The part must be tested and eventually replaced.
Here replacement parts for most flat panel TV models:ShopJimmy.
See also:
PartStore
Regards.
Ginko.
Dez,
Bill
[email protected]
3answers
If it's not yet a year old it should have some warranty - take it to the shop.. It's probably the HOT (Horizontal Output Transistor) which have been a problem child in this series all the way back to the TXP2745... But don't even crack the case on this one if it's that new - labor might not be covered but parts might. In any event replacing the HOT is not a difficult or expensive job.
Bill
1helpful
3answers
Samsung TXN3298HF 32" Flat CRT is dead, please help
Hi I have a Samsung Tantus Dynaflat 32 inch flat screen TXN3298hf that all of a sudden stopped working...no power no nothing. We opened up the back and found that a 5 amp fuse had blow. This fuse regulates that power supply to the tv and can be found at the end of the power cord prior to the circuit board. Hope this helps.
Noise Issues with Samsung Dynaflat TX-P3264H
yes ur right that is a flyback that is leaking! it produces a high pitch sound. well if u want to be sure that ur part is genuine. go to the manufacturing authorized service center. for sure they have available part. try also to look into the horizontal cuircuit. there might be something else that was damaged. probably the horizontal output transistor. gud luck
Samsung DynaFlat TX-P3064W 30" TV Logo
Ekse
Demonic-2011
Demonic-2011
