The error code shows and I cannot open the door. How do I check to see what the problem is and how do I fix it? Thank you.
Opening a locked door , click for a visual demo: Door locked#
It is possible that the actuator to the lock has failed and so is not releasing or there is a error on the control panel.
SOURCE: MAYTAG NEPTUNE ERROR CODE OE
The "oe" code indicates a water pressure problem. Remove the water supply hoses and check the small metal screens inside the water inlet valve. Make sure they are clear of rust or debris. Check the water inlet valve solenoids. They can can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid I will attach a photo for reference. Hope this helped and best wishes.
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
SOURCE: Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach
response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control
doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3”
code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire
harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a
separate part, but rather an integral part of the motor.
SOURCE: my maytag neptune washer model
there is no "red string" on this specific model. Its really irritating that everyone is saying this when clearly no one can find a red string. Stop giving this advice. From what i can tell so far the release lever is inside the machine and to get to it you have to remove the front panel. My problem now is i cant get the top electronic panel off to get the front panel off... this machine is like a giant chinese handcuff!! I will never buy a maytag ever again!!
