Washing Machines Logo
Question about Hoover Washing Machines
Hoover DYN8144D FAULT READS E103
Posted by Fergs Jordan on
  • Hoover Master
  • 17,130 Answers
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jul 06, 2012
My hoover dynamic 8+ washing machine Model number DYN8144D-80D displays an E08 error Code
E08 is the motor speed sensor error code. Suggestion: Try a cycle with very few garments and see if it completes the cycle.
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Hoover dst10146p error 103
I recommend to read you troubleshooting section and see what is the cause, would be the cause pressure switch NOT sensing.
or download from www.retrevo.com
2helpful
Always say no data...i already use sonic stage
http://www.sonydigital-link.com/dna/wm/nwf/nwf.aspx?site=odw_en_GB&m=NW-E103 just read the manual user at page 56 i mean format the device and after that use sonic stage when putting music in your mp3
Error code E103
there are three posible causes for the above mentioned problem
  1. Scanner lamp blown
  2. thermistat blown
  3. Home position sensor is not working
One or a combination of these three conditions will cause E103 and hense you can replace as appropriate.
Top Hoover Washing Machines Experts
W.L.
Steve F
Mike
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
