Archos AV 500 Digital Media Player Logo
Posted on Jun 27, 2017
Downloading What I meant was , before they changed to digital, I could download programs that I saved on my DVR to Archos, like three to four programs all at once in a matter of minutes, as long as it wasn't high def, so I saved programs that was 'nt in high def, but now since they changed the systems it won't allow me to download from my DVR, it now says this is a high def program, so I now have to record everything in real-time.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Feb 05, 2008
SOURCE: archos 605 wifi 4gb DVR issue
the power is low because you did the
same thing as me not chargeing it before you turn it on first
ken stofferahn
  • Posted on May 09, 2008
SOURCE: archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Anonymous
  • Posted on Aug 26, 2008
SOURCE: TV PROGRAM GUIDE
delete the epg programe from your archos then when connected to the archos web site through your pc download the updates this should work
Anonymous
  • 22 Answers
  • Posted on Apr 27, 2009
SOURCE: tv program guide will not update when connected through my dvr
The TV Program Guide is actually controlled by a 3rd party.
I registered my Archos at Archos.com when I bought it......I'm not sure how you'd stand with a 2nd hand one.
Basically, the website tells me that I only have 82 days left to my TV Program Guide 'subscription' and if I want it for another year, I have to pay £14.90GBP!
However, I can tell you that the Program Guide is pretty rubbish. All it does is let you record the SAME channel that your TV is showing. It does not record a different channel if you want to watch something else and if the TV is switched off, it doesn't record at all!!
Reading the manuals and the reviews on the Archos website, I was led to believe that it would do all of the above, but when I tried to get help from Archos Support, they basically told me that it doesn't do any of that!!
As much as it p'd me off, that is the only flaw I have found in the Archos and the other things it can do are quite amazing.
Try searching for 'Archos Forum' and check out some of the features - it is a remarkable machine!
Anonymous
  • Posted on Jun 12, 2009
SOURCE: Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
3helpful
I need a manual to operate the remote control for the Archos DVR Station for 604, 504& 404. Thank you.
user manual:
http://www.archos.com/support/download/manuals/user_manual_dvr_station_imt_v1.pdf
connection sheet (USA):
http://www.archos.com/support/download/manuals/connection_guide_usa_dvr_station_imt_v1.pdf
connection sheet (Europe):
http://www.archos.com/support/download/manuals/connection_guide_euro_dvr_station_imt_v1.pdf
1helpful
3answers
Downloading of dvd on to arcos 7
I use this software to copy DVD for my PSP, works great.
http://www.123copydvd.com/
Hi i have a archos 405 and it goes to recovery code 102 and will not repair or format disk any ideas on what to try?
Iv had this go to your Archos and do RECOVERY Then go to your computer load the Archos programe. Go to you archos account and find the updates for your Archos. Right click and SAVE TO YOUR COMPUTER NAME IT Archos 1..Do the same with the secound and third Updates if there are anymore.
Now you will need to see your Saved program which should be on your desktop and your Archos in your MY COMPUTER Reduce both these so you can see them .
Nearly there
Go to my computer Drag and drop the First programe Archos 1 onto the Archos in My Computer Go to your Archos and click OK
THIS WILL TAKE UP TO 3 - 4 MINS TO DOWNLOAD
gOOD lUCK
Can you connect an archos 605 to a bell 9142 pvr
Archos Dish Network Plug-In says:
  •  Quickly transfer hours of your favorite TV programming from select DISH Network DVR receivers and enjoy the shows you watch every day- on the go.
  •  DISH Network customers with ViP622TM and ViP722 TM DVR receivers can enjoy this next generation of PocketDISH service with Archos 605 WiFi and Archos 705 WiFi models
  •  This plug-in is free for DISH Network Customers.
  •  Not a DISH Network customer? Find out more at www.dishnetwork.com and get the most out of your Archos player today
  • 0helpful
    Can I pre record on the archos 605 wi fi 30gb
    You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
    1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
    2) You have to have a digital cable box, FIOS, or digital satellite box.
    You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
    http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
    Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
    http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
    If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
    There are two catches that I noticed with this player - 1 major and one not-so major:
    1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
    2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
    -Tha Mp3 Doctor
    1helpful
    DVR to Archos
    That's what the DVR does. All you need to do is play whatever program you would like on your cablebox/DVR and hit record on your archos. It will record it like any program.
    DamPinou
    3answers
    Archos 504 dvr shuts down when I plug it into the tv and there is no sound.
    The same thing happens to me. I've noticed that it is on the dvds and vhs recordings (ie, copy protected) that this happens. The other files (downloaded from internet, tv, etc) play fine. I think it has something to do with copy-protection that allows files to be saved to device, but not transmitted out. This allows you to save and view your commercial recordings on the Archos, but not let the program to be sent to a recording device such as a dvd recorder.
    Can't get the dvr working
    ARchos is macrovision compliant to prevent copying copyright programs. I think in some cases the recordings are encoded as such and will not play on your tv in those cases. I would fire off a letter to Archos technical support archos.com) and check with them on this.
    Top Archos Audio Players & Recorders Experts
     Grubhead
    Grubhead
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
