Question about Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard
Ok so i have an ASRock NF6G-VSTA motherboard, wired up correctly as the manual says yet i have absolutley no power to USB, completley dead. Any ideas on whats up? Running Win 7 4GB of DDR2, HD5450 card.... everything done by the book yet when i boot i have absolutley no power to my USB peripherals...
    New Friend:
  • 124 Answers
Check weather the front usb cables on mother are connected properly or not or alse try another connecting other usb device
Posted on Jul 05, 2012
  • thepadstar
    thepadstar Jul 05, 2012
    i found the problem only a short time ago, oddly it was my keyboard causing problems... i unplugged it and boom everything works... got a new Keyboard to test and its fine.
5 Suggested Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: USB Power Issue with ASRock K8 Combo m/b
Are you plugging in to the usb ports on the MB, or on the case?
Posted on Jan 14, 2008
Anonymous
  • 87 Answers
SOURCE: i need a free driver for asrock Alive NF6G-VSTA
http://www.asrock.com/mb/download.asp?Model=ALiveNF6G-VSTA&s=AM2
follow the link
Posted on Apr 27, 2009
jimmy Leo
  • 50 Answers
SOURCE: Asrock ALiveNF6G-VSTA Motherboard. Unable to boot to OS
first disconnect ALL cables except power suppliy and frond panel switch. Startup and see if goes further.
dont forget to disconnect the front panel usb cables also !!!
if it goes better, connect he keyboard, reboot and enter bios to see.
etc etc
if it still hungs up at the start with all cables disconnected then a major chip on your motherboard is burnt (maybe the disk controller).
sorry i dont think a solution oher than buying a new motherboard.
Posted on Oct 10, 2009
raicath_3445
  • 40 Answers
SOURCE: Running windows 7 64-bit OS
the graphic card possibly not recognized cause its 64-bit OS try the window 7 ultimate.. or update the graphic card by manual..
my computer->device manager -> then right click the graphic card which has a question mark (?)
then right click and update it with your cd installer..
Posted on Oct 22, 2010
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: asrock k8nf6g-vsta motherboard will not power up
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Jan 13, 2011
USB 2 use to work when trans- ferring files then it just stopped, have got USB 1 but to slow
Have you got the original disk that came with your motherboard? If so just reinstall the 'chipset' drivers and you should be OK.
Sep 14, 2014 | Asrock AM2NF6G-VSTA Motherboard
Alive nf6g - dvi lan problem
Get online and got to www.google.com Inthe google search box type: "Acer Support" (without thequotes). Look for downloads and drivers. Enter your model numberand operating system when requested. Download and install the drivers
Mar 27, 2012 | Asrock ALIVENF6G-DVI Skt AM2 Nvidia...
I HAVE AN ASROCK MB,ALIVE NF6G-VSTA, BIOS PL.50.I STARTED UP.EVERYTHING GOES BUT IT READS ON SCREEN :press F11 for boot menu,and below that it reads:single channel memory mode.IT STAYS THERE and it doesn...
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Oct 28, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Doesn't support windows xp operating system
Hello Hanimip!
Asrock has Windows XP drivers for your AM2NF6G-VSTA motherboard available for download on their website. The link for the Windows XP drivers is AM2NF6G-VSTA
Nov 19, 2010 | Asrock AM2NF6G-VSTA Motherboard
etc etc
Oct 10, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
I need free sound card and video card
http://www.asrock.com/support/download.asp?Model=&Socket=AM2&Product=ALiveNF6G-VSTA&OS=XP - here are your free drivers. Download the one that indicates AUDIO and VGA on the left column click on the download icon on the right side.
Apr 27, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard Logo
327 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
ChinthakaJ
ChinthakaJ
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
