Hi Lee,
I'm sorry to hear you're having difficulty with your DC15. If you'd like some help, please give us a call on 0800 298 0298 - we may be able to resolve the issue with some troubleshooting over the phone.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
SOURCE: My Dyson DC15 has suddenly become very reluctant
Hi its Darran at Dyson.
Although strange, I believe we have a solution. It sounds as though the cleaner head hose is blocked. When the machine is running the suction will be pulling against the bloskage causingt he hose to contract and prevent it from swivelling the left. When switched off there is no resistance in the cleaner head hose which is why it moves normally.
You simply need to check and clear the blockage from the cleaner head hose and this should resolve the problem.
Details on the blockage procedure can be found on our website at www.dyson.co.uk/support. From the Support section homepage, click on "My machine is not working", pick you machine and follow the diagnostics for my machine is not picking up correctly.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
SOURCE: DC15 Animal brush motor not working?
Same problem but all fuses etc ok I found that there are two wires that move with the head,orange & white located in the left hand bottom panel(side of vacume). they had broken bought some conectors from maplin & all fine now.
SOURCE: My Dyson DC15 has stopped
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
Lastly, can try calling their helpline at
866-MyDyson for further help.
Check the above link to see if it helps. It shows you how to break down the
DC15 to check for issues.
Also try inspecting the circuit board for loose wires.
SOURCE: dyson dc15 bagless upright. my brush bar is not
You can try calling their helpline at 866-MyDyson for further
help
wires. There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board.
SOURCE: My dyson DC15 the brush cuts in and out.
You can try calling their helpline at 866-MyDyson for further help
Check the above link to see if it helps. It shows you how to break down the DC15 to check for issues.
Also try inspecting the circuit board for loose wires. There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board.
And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Lastly, can try calling their helpline at 866-MyDyson for further help.
help
