Philips HD4651 Electric Kettle Logo
Question about Philips HD4651 Electric Kettle
Need power cord for philips hd4651 electric kettle
2 Related Answers
Anonymous
SOURCE: I need a replacement seal for a Philips kettle HD4681
what is the solution for electronic harmonics & producing power
Posted on Jan 02, 2010
Saul
  • 4 Answers
Try the two links:
1.
http://www.tsnova.cz/p71357-tesneni-pod-konvici-996500030291-pro-philips/
2.
http://www.chsinteractive.co.uk/electrical-components/small-home-appliances/kettle/philips-10/miscellaneous-10/sealing-ring-kettle-philips-996500030291-hd4680-hd4681.htm
Posted on Jul 18, 2015
Information to question already asked the fact the power is lighting both lights up but no noise of starting to boil does this kettle need a new element and if so where can a get it fixed.
You are not specifying what make it is but you hardly get replacement elements for kettles any more. The fact that you can see that power is available at the kettle it is indicating that it might be the element being defective. Had it been it switched on without any water in it? If it is the old type where the electrical cord gets plug in at the kettle check if it is well plugged in otherwise it is time for a new kettle.
There seems to be a loose connection between base and bottom of kettle . At first I could press down on the pot and it would start heating . Now I can
If it uses a detachable base to the kettle tank with electrical contacts, sometimes the base or kettle connector must be replaced. You will need the proper tools and wire connectors to be able to replace these parts.
Technically speaking... These are not worth servicing.
Jerry G.
1helpful
Kettle not boiling water
Please use a multimeter and check the continuity of the power cord , now switch on and test the coils resisitance. If there is no continuity then the coil is open and the element has to be changed.
You need to contact spares dept of murphy richards.
please check the link below for spares;
http://www.espares.co.uk/search/kettles/p/1102
1helpful
Power cord overheats
The thermostat is not shutting the unit down and cycling it on/off as it should. This will cause the power cord to overheat and it will catch fire. STOP using this unit and either replace it or have it repaired. More than likely cheaper to just replace it.
Need new base
Try http://www.support.philips.com/support/service/onlineStore.jsp?userCountry=us&userLanguage=en
At the top corner you can choose your country, and hopefully you'll be able to locate a local Service Center
2answers
It will not heat up. It needs to be reset. How?
If the unit overheated the boil-off protection is actuated. Unplug the base power cord. Let the unit cooldown if needed. Replug it in. Should work
Replacement Power Cord
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the pot with you to make sure you are getting the correct cord.
7helpful
2answers
How to descale Philips HD 4651/C Electric Water Kettle
Not having received any solution message from FIXYA contributors, I consulted with a family member
and also my long held Time-Life Books, Fix It Yourself Library, Volume: Cleaning & Stain Removal,
ISBN: 0-8094-7400-X, Copyright 1990. My issue was resolved by using white vinegar and soaking the internal problem area for 30 minutes. The appliance has cleaned up like new and works fantastic. I apologize for bothering you.
HD 4651/C Electric Kettle Handle switch lights but wont heat
This maybe the thermo fuse, and or the heating element that is defective. These parts must be properly replaced for safety issues.
Usually these appliances are not worth to service.
Jerry G.
Top Philips Kitchen Appliances - Others Experts
Thomas Perkins
Thomas Perkins
ray gallant
Kardoc
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
