Question about Zapco Car Audio & Video
Need parts for zapco c2k 2.5x
Need bin front and rar and lave output to rca
1 Related Answer
Anonymous
  • 3130 Answers
SOURCE: ZAPCO 9.0
Go here first http://www.zapco.com/ Good Luck
Posted on Aug 06, 2006
I installed a 400 watt zapco competition amp\ front speakers play ...back woofers don't?
are you sure you didnt wire the amplifier the front and rear to
left/ right?
check your deck settings to see that the rear speaker rca are connected.
check all wires are connected.
push the mono or bridge buttons are off.
provide more info.
Nov 03, 2013 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
I have a zapco refrence 750.2 has no sound output when bridged but works fine when i run a speaker to each channel. any ideas on whats wrong?
check your settings on your stereo and the amp make sure you have changed to 1 ohm on the amlifier for a briged connection to a subwoofer and change from lpf to hpf on the amp there should be a switch.
Jun 07, 2010 | Zapco Reference 750 Car Audio Amplifier
I have a zapco model PEQ board and i need the cable/wire wiring instructions can you help me?
The plug consists of a 7 pin plug which contains a ground, a hot lead for the PEQ itself, a neutral for the PEQ, and a hot and negative for each L and R channel, respectively. I had mine changed to RCA's years ago by a local shop, then soldered the connections myself after the proper connections were changed at the shop. I now have the signals changed into a Symbi-Link Transmitter/ Reciever System (unbalanced to balanced inputs) and am able to de-tune the PEQ and still get more output. It's fun... Hope the info helps.
Jun 01, 2010 | Car Audio & Video
...storing noise detected from my
Storing as in Distortion? If that's the case lower the output gain from your amp until it is suitable to you ears. It might be all the way open, besides this should be adjusted system to system.
May 31, 2010 | Zapco Reference 650 Car Audio Amplifier
Zapco DC Reference 750.2 problem
If the amp uses TIP35Cs and TIP36Cs, those will be the output transistors. Measure the resistance between legs 2 and 3 for each of the output transistors. Do any read near 0 ohms?
If you're new to repairing amps. The following page should help.
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Nov 16, 2009 | Zapco Reference 750 Car Audio Amplifier
What is the wiring orderfor the zapco seq
the basic wirings are for inputs, power and for the speakers (front and rear). If you open up the device and trace the wires to the fader control (electrically), those are for the speaker outputs. The power supply line is much easier to locate through the power capacitor..maybe. watch out for the remote wire if it has one (this triggers the device to power ON). gudluck!
Apr 10, 2009 | Car Audio & Video
What is the left and right clip light?
the left and right clips are for your subs to tell your amp that they are not going to (flatline) clip which is when you start to lose clarity and get distortion
Feb 19, 2009 | Zapco C2K-3.0X Car Audio Amplifier
Zapco 18 band eq
You will need to call the manufacturer, ZAPCO - 209-577-4268, or email them at tech support [email protected] , in order to purchase the part you are missing. It is possibel to hard wire the RCA parts you need and creat a homemade fix, but in all honesty it is not worth it, and it will probably introduce a lot of interference in to the quality of your signal path rendering it a bad option. Give them a call / email. If they will only sell the part to a dealer, call Car Depot @ 615 - 269-8080 and they can have the part purchased and delivered to you for a small fee. Good luck.
Feb 01, 2008 | Car Audio & Video
ZAPCO 9.0
Aug 06, 2006 | Zapco C2K-9.0XD Car Audio Amplifier
Car Audio & Video Logo
56 people viewed this question
Top Zapco Car Audio & Video Experts
Marvin
Marvin
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
