Click here to download the user manual to your remote control. It has all details.
SOURCE: RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
SOURCE: RCA 27V412T TV Problem
sometimes its not the connections... but its the toggle switches at fault
SOURCE: help my rca model 27v412t tv is going nutts
RCA HAS A KIT! which includes different solder and some paste for a better solder flow!
I resoldered mine without knowing that and it lasted 7 months before it started up again.
so now I'm on the way to givin it a total resolder on every component that creates heat , hopefully that will last another 7 months at least , also note that I replaced R033, R034, and C230 , if this continues to do it again I'm going to replace EEPROM and x001( crystal at 8.000mhz) and the IR sensor. I'm guessing that rca must have known that the sets heat up and the solder joints become bad ,I belive that the flyback and other hot components will do the same thing , as I also belive most of the models of this type chassi will encounter the same issues comming from bad solder or dried solder, if problem is not corrected soon then EEPROM the crystal and other components will suffer severe dammage, then the set is just another piece of history.
good luck to those who own one
SOURCE: Converter box remote will not program
i have a admiral tv and i'm wanting to program my remote that goes to my converder box to the tv is there anyway i can do that?
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
