Question about Sharp AR-5316 Advanced Digital Imager Copier
The printer Ar-5516 is showing H4 error - Sharp AR-5316 Advanced Digital Imager Copier
Posted by sooraj312 on
vahidzz
    Habit-Forming:
  • 41 Answers
This error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Posted on Jul 26, 2012
foufa
    New Friend:
I have sharp ar 5516s displays error code l4. can you help me please
Posted on May 08, 2014
5 Related Answers
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Ar 5516 display H4 error
H means heat, you need a new fuser.
Posted on Mar 28, 2010
Anonymous
  • 37 Answers
SOURCE: SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Posted on Mar 01, 2009
Anonymous
SOURCE: sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Posted on Aug 25, 2010
Anonymous
  • 118 Answers
SOURCE: Sharp AR-M450 is showing error code ''H4-00''
You're getting a heat roller low temp detection on the fuser in your copier. The fuser is the device that provides heat and pressure to the toner to bond/fuse it to the paper (it's that black, rectangular box in the upper part of the body when you open the left-hand side of the door).
Chances are a peice of paper is jammed up inside and blocking the sensor (probably a small peice that tore from a page someone tried to pull from the fuser). That or the temp sensor is defective.
Posted on Aug 21, 2009
Anthony Karuku
  • 268 Answers
This means that the fusing unit has a problem. Turn off the copier. Open the small side cover on the right of the fuser unit. You will see the wire connectors leading from the unit and carefully remove them.Open the three screws holding the unit and remove it, check the heater lamp continuity if out replace the lamp. Clean the thermistor and return the unit by reversing the removing process. Now try the code and it will work.
Posted on Mar 30, 2010
Why i get H4 error on 5516
Heat roller abnormally low
temperature
When the temperature does not
reach 155°C within 55 sec after
turning on the power, or when it
falls under 145°C during printing,
or when it falls under 100°C
during pre-heating
May 28, 2014 | Sharp AR-5316 Advanced Digital Imager...
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
Jun 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Sharp ar 5516 printers error h5. h4
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Mar 28, 2010 | Sharp AR-5320 Black and White Copier
Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Aug 18, 2008 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
5,039 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
