Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Do you have the hi def cable for ur ps3
Posted on Jul 04, 2012
i just have the AV cables for now. would they work?
i would go get the hi def cable
but u can try those first if they dont work i would get the hi def cable
ok thank you so much for helping out. ill try to work with the AV cables, if they don't work then ill go for the hi def cables. highly appreciate yr time.
oh just one more thing, are hi def cables and hdmi cables the same thing?
yea
when u go get one just look gor the cable that says hdmi
SOURCE: Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: i am having problem setting
I do not own a PS/3, but I will try to help just in case you dont get another expert at this late hour....
It sounds like you need to save the changes on your PS/3. It is timing out and going back to default because the changes were not saved.
Hope I helped!
VA
Posted on Feb 11, 2011
SOURCE: Cannot connect my PS3 to
Does your TV work on VGA, it maybe worthwhile getting a HDMI---VGA lead and try that as it sounds like your TV isn't working, and you've tried the obvious. Do any other HDMI devices work on your TV, like DVD HD/SAT?
Posted on Apr 22, 2011
SOURCE: I have a panasonic Th-42pv500a.
the playstation detects that you are changing display settings. hopefully you still have the old red yellow and white cord that we all used to use to plug in stuff to your tv . use this cord to connect your playstation to the tv, it should pop up that you want to change display settings. then after you go through that unplug and recconect the hdmi and it should run you through it again, Another option - when you plug in your ps3 to the tv , turn everything on the tv and playstation. if nothing pops up turn off your tv and playstation , literaly unplug them from the outlet for a good minute then plug everything back in and you should fix it that way. hope one of these work
Posted on May 05, 2011
Apr 13, 2018 | Panasonic Televison & Video
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Jan 17, 2014 | Panasonic TH-42PC77U TV
Dec 20, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Feb 14, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Jun 14, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Feb 28, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Dec 30, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Oct 23, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Apr 09, 2008 | Panasonic 50 in. Plasma TV
317 people viewed this question
