The vchip is active and i dont have the password or the user manual
If you did forget the code to release V-chip to this TV, there is no other way than contact its authorised service center. If you want to unlock the child-lock to certain channels:
Press or to display the password entering mode.
Press MENU, then press or to display the (LOCKS) menu.
Use the number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
Press or to highlight CH LOCK and press or to display
the CH LOCK menu.
Press or to highlight CLEAR and clear all channels from the
list of locked channels. Press ENTER.
5
6 Press EXIT to return to normal viewing.
SOURCE: Reset Parental Control
There you go:
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up].
2)
Enter 4-digit access code with the Number buttons. If you have not set
up your personal access code, enter 0000 (default access code).
SOURCE: I dont have vchip code fof my used tv
1. Hit the Menu button on the TV.
2. 'INPUT SECRET No.' should appear.
3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears.
4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
SOURCE: vchip
Here's the link to the user manual if you need it; http://disney.memorexelectronics.com/downloads/dt1350cin.pdf Check page 9 "If you lose the password, you can cancel the existing password by the following procedure: - Keep pressing Volume button of the main unit and press ?0? key of remote control simultaneously for a few seconds." Hope this helps :)
SOURCE: Need Owners Manual
tv.manualsonline.com/manuals/mfg/zenith/c27j28c.html
you can downlad a free manual here or u can register yourself and they ll send a manual copy to ur mail when they get it
SOURCE: need to unlock vchip passcode; factory reset?
v chip block just popped up on screen , and i never set the tv to v chip
