I put a MCP61PM-HM (Nettle) motherboard in a gateway 500s case and the front panel power,LED,Reset,etc... plug does not fit the 9 pin power header on the motherboard. I was hoping to find out what each pin on the mother boards power headers functions are. If someone could please assist me it would be appreciated. Hopefully I can place the correct wires to the pin that its supposed to go to. :)
This motherboard Adam?
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
Can't help you.
OH, I'm just KIDDING!
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
On the motherboard the Front Panel header is marked as PANEL1.
Scroll the page down, until you come to Motherboard layout.
Click on the + sign to the left of it.
Shows an illustration of the motherboard.
Bottom/Right corner is PANEL1. The black rectangle that is sitting vertically, in the motherboard photo.
Motherboard installed in computer case, the Front Panel header is two columns of contact pins.
FOUR on the Right side, FIVE on the Left side.
I don't know the actual numbering of the pins, so I'm going to number them myself;
Starting on the Left side at the Top, going down,
Pins 1, 3, 5, 7, and 9.
Starting on the Right side at the Top, going down,
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. If not, do not connect to them.
C) Pin 9 is N/C. Not Connected. It was a +5 Volt power for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) NO pin 10, just a blank spot.
How to find out what wires are what, in that Front Panel harness connector?
Follow the wires from the connector, up to the Front Panel.
Front Panel removed it is easier to see where the wires go.
You can follow the color code of the wires, and see which twisted pair go up to the Power On switch.
You can also see which ones go to the Power On LED.
(Light Emitting Diode, so it is a light)
Reset switch, (IF there is one), same thing.
The only pair of wires that will be left is the HDD LED wires.
HarDDrive activity LED.
The 9-pin plug will have to be CAREFULLY cut apart. Separate the wires, AND their metal terminals. (WATCH your fingers!)
For additional questions please post in a Comment.
Regards,
joecoolvette
SOURCE: HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
SOURCE: Can't Fix FRONT PANEL HEADER on my Motherboard
Here is a link to your motherboard manual:
D845PEBT2 Manual
Go to Page 33 for the Front Panel connections...with pictures. :-)
Thanks for using Fixya.
SOURCE: MCP61PM-HM spdif pin assignment? trying to
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
SOURCE: I have a MCP61SM-AM motherboard.
u can download the manual guide at:
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000903
the front panel connector is in page 18. im sorry i cant upload the diagram.
hope this useful. regard riyan.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
