Unless someone has NOS parts most likely new boards are not available. (New old stock) I would check ebay unless you have some electronics repair experience. I would be glad to walk you through some test procedures.
I am currently working on a Fisher RS-929.It took a static
lightning strike through the antenna connections on the tuner board
what I have found so far is a blown coil, which I rewound, and
3 7812 voltage regulator transistors.if either one of these devices are bad the display(control board will not operate)I will keep you updated on this repair as I expect the replacement parts in this week. Hint:it is best to replace all three and check the two bridge rectifiers also. As these systems were built in 1996 it is doubtful
that replacement boards are redily available
You would have to install a speaker selection switch. You cannot directly hook up 2 amplifiers to one set of speakers without destroying one or both amplifiers. Unfortunately, one set of amplifiers is inside your sound bar. An external switch would have to be installed on your sound bar as well as speaker terminals that would connect to your Fisher.
If you have a line out or tape out on your Fisher, and you have an analog input on your sound bar, use could use that as an alternate solution. For more information, please visit my website at audioserviceclinic.com. Thank you.
Hello you can get the parts from any New Zealand F & P service center( $50-80nz). You need a special F & P tool kit (you can buy for around $100nz from F & P also) to remove the seal and bearings and to insert the new. unless you know an appliance tech or have a service manual it could be a tricky one. cheers
