Question about Samsung PN51D550 51 3D HDTV Plasma TV
Samsung pn51d550c1f screen is cracked where can i get a new screen
The screen is cracked and there is sound but no picture. When the repair man fixed my parents screen on the same type of TV it cost them about $800 is there any where else I can purchase a screen so I don't have to pay THAT much on a stupid screen?
Posted by kaitie_lynn_ on
    Top Expert:
  • Samsung Master
  • 76,416 Answers
2/3rd of the total cost of a Plasma Tv is with its screen itself. Just contact the nearest authorised service center for Samsung, to know the exact price of it at your countty.
Posted on Jul 04, 2012
5 Related Answers
Anonymous
  • 84 Answers
SOURCE: CRACK LCD TV SCREEN
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it. LCD screens really break easily as you know. http://www.tv-armor.com
Mike
Posted on May 21, 2008
Anonymous
  • 15 Answers
SOURCE: Samsung LA40R71BDX - Black screen, No picture but had sound
LCD screens are monolithic (one piece) components. They cannot be repaired, they can be replaced. One site I found for replacement info is http://www.screentekinc.com, they even have DIY info if you are so inclined. There are many other sites; do a search on "lcd repair"
Posted on May 12, 2007
Anonymous
  • 118 Answers
SOURCE: Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Posted on Jan 30, 2009
Anonymous
  • 150 Answers
SOURCE: LN-T4671 started clicking
hi, veeery common problem, bad caps in the power supply, put in higher voltage rated caps and it won`t happen again, video-tek
Posted on Jun 05, 2009
Anonymous
  • 4 Answers
SOURCE: Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
Hi, my 45" Sharp Aquos
PTS they rebuild boards at low cost 1-800-844-7871
Shopjimmy.com might have boards.
Encompass Parts Distribution 1-800-638-3328
May 31, 2011 | Televison & Video
My tv fell and the screen cracked in one area. The TV works, however, there's no picture and only sound. I can fix it?
No,the LCD screen panel is dead,not repairable.By replacing the LCD screen panel,will cost the same as a new tv.The entire tv the LCD screen panel is the most expensive and limited productions by the tv corporations.Sorry tv now only worth as a salvages tv for it electronic boards for spare parts for another tv,that it.
Dec 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Crack beneath screen
I hate to bring bad news but it's better cruel truth than sweet lie.
You got so-called "physical damage" of your LCD panel. Surface that you can touch and one that looks intact is just a protective layer. Behind it is fragile class of LCD panel. Sometimes kids tap toy into the screen and parents later guessing what's wrong with TV.
No manufacturer (that covers first 12 months) or extended warranty will cover this repair. Technician will show up for free of charge, take a pictures of the screen and leave you with this problem. Whole LCD panel have to be replaced and part alone could cost up to 80% of cost of new TV.
Unless you can prove that this is shipping damage (I doubt it because it is not that you calling retailer very next day after purchase) - there is nothing that you can do to get out of this situation cheaply.
Still you need to call manufacturer customer service and have technician from authorized service center to show up and inspect it. Maybe we both wrong and you have a case of defective panel. Really hard to determine without seeing pictures of how your LCD looks like.
Sorry again and good luck!
Russ.
Apr 06, 2010 | Sanyo 42 in. LCD TV
Can a plasma tv be repaired if the screen cracked also the picture is only like three quaters size.
The display screen is the most expensive part to replace in your plasma tv. In most cases its cheaper to buy the same model. Instead of buying the part and paying a repair man to fix it....Broken screen = junked plasma
Aug 27, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Remote hit the TV and crakced LCD TV SCreen
There is no way you can fix a broken screen of a LCD set,the only way to fix it is by replacing the complete panel wich will cost more then a new set.
Aug 05, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen has a little scratch there is sound but on picture with little thread lines coming form the scratch
you likely need a new tv. on the insides the audio pieces are a lot tougher than the delicate pieces that create the picture for you. if it was dropped and something hit it and it cracked losing your picture, I am pretty sure the tv is toast.
May 19, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
Apr 20, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
No picture and only buzzing sound coming from plasma with cracked screen
sounds like you may have a high voltage arc and / or leak . better to let a manufacturers qualified technician have a look at it this time . ask for an estimate after diagnosis and before repairs are made. factor age plus repair cost v/s a replacement tv . also in the area where i live most in shop repair estimates are cheap or even free . field repair estimates are definitely not . all tv parts can be replaced but, screen replacements can get expensive . barring neglect , abuse or a significant power surge you should not be having these problems on a tv so new. double check your warranty. most electronics come with 1 year on parts ,90 days on service. some warranty limitations are not allowed in certain states. also contact the manufacturer . in my expierence some of the better companies have honored an expired warranty partlialy and sometimes even fully on a relatively new product . after all they do have reputation to lose or keep . just be courteous and if your lucky they will be too. but if all else fails, i personaly prefer lcd flatscreen . oh , about the screen crack , clean and position your tv according to the owners manual . some of todays televison components are even more thermaly and chemicaly sensitive than ever . ie; window cleaner can whiten or even crack certain types plastics. finaly if you are not using a good surge protector now may be the time.
good luck
Feb 07, 2008 | Televison & Video
My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Nov 20, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung PN51D550 51 3D HDTV Plasma TV Logo
2,020 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
