I suppose you are using carbonized paper to obtain 2 copies... Then probably the first sheet of paper you are using (the one over the carbon paper) is too thick. I remember that when one wanted to make copies, it was important to use thin paper or the copy (the page under the carbonized paper) would appear too pale. Try with a thinner paper, especially as the paper used in printers and photocopiers is stronger than the one that was produced for typewriters.
Hi. There is a lever (left side) to set the thickness of paper. Move that to lower number if you only have 1 paper, move up if you have several pages. Hope this helps.
this is only a possible solution.make sure the paper is between 17 to 24 pounds thick.i once had a jamming problem and it turned out to be the printer which canon replaced under warranty.but in the process i learned paper thickness can make a difference. i was recommended 20 pounds by a staples employee.i hope this helps you.
