Others are correct in that if one upper element fails , the other upper element cease to operate. Thus I need one upper element OR will an element from another GE toaster oven ,or for that matter another brand fit and function properly ? please respond to: [email protected] I
SOURCE: Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
SOURCE: sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
SOURCE: I have a new GE Covection Toaster Oven model
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
SOURCE: Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
