Question about Kenmore 98702 Stacked Washer/Dryer
My Sears Kenmore Dryer has stopped spinning!
I have a model 417.91702000 Serial number xe14002479
For a while it was making a squeaking / Grinding noise. So I was going to grease the bearings now it has stopped all together. I opened it up and the belt that is around the drum is still in tack. Is it the motor? I am a stay at home mom and I have been fixing other things around the house. I am trying to save money by fixing it myself. I feel I am pretty handy I fixed my Fridge and dishwasher by myself. So any info would help greatly. Thanks
Posted by dawncespedes on
5 Related Answers
Anonymous
  • 306 Answers
SOURCE: Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Posted on Dec 11, 2007
robert samples
  • 1314 Answers
SOURCE: Dryer Squeaks
ok your having the begings of a rear bearing problem now let me tell you whats happing if you pull the dryer out and look about at the middle of where the drum is at the back then you will see a silver small rectangle peice in the middle of that is what looks like a small finger with a steel ball under it on the little ledge there should be a little pile of black dust the little finger is making the little ball cut into the back of the rear bearing but the rear bearing is still good now get you a little can of spray lithem grease clean the dust off turn the dryer on and spray that little ball till its coated then every time you hear it squel repeat the proceadure untill one day it wont stop then we will have to change it and on that day you better have some help lol
Posted on Mar 31, 2008
Anonymous
SOURCE: Kenmore front load washer
I had the same problem and it went on few months. Then the final spin didn't work and I could smell something buring. Called AHS and they sent a tech, who said it was the bearing. Cost about $350. to fix. Will be replacing the washer soon, I don't think we paid too much more than this at the scratch and dent place.
Posted on Sep 06, 2008
Anonymous
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Posted on Mar 10, 2009
My kenmore dryer is making a loud noise when it is going\model #970-C8909700 serial #4D02001824 it is 14 months old
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 02, 2011 | Kenmore Dryers
My Kenmore front loading dryer, 970-C85192-00 starts drying with a load squeaking noise. Once it warms up it stops. Could it be a belt?
usually this is a drum roller replace both very inenspensive and u can order parts directly threw sears.com recheck model number get off appliance data tag on appliance
Jan 28, 2011 | Dryers
My dryer squeaks when running. Is there something I can oil to make it stop?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 23, 2011 | Kenmore 500 6952 Dryer
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
Kenmore Oasis top load washer model 100 27072603 makes loud noise when it is spinning to dry. Sounds like bad bearing?
heatman101
Jan 15, 2011 | Kenmore Washing Machines
Squeak
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Nov 29, 2009 | Kenmore 98702 Stacked Washer/Dryer
Need to know year of model # 66814690 sears kenmore dryer
The date of manufacture is determined by the SERIAL NUMBER. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
Kenmore dryers are manufactured by Whirlpool. The "110" prefix on your model number identifies the manufacturer. If you still require assistance, post back with your complete serial number and I can explain how to determine the date for you.
I hope this helps you.
Sep 24, 2009 | Kenmore 66862 Dryer
My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Jul 31, 2008 | Dryers
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
284 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
