Dell XPS 420  PC Desktop Logo
Anonymous Posted on Jul 03, 2012
Dell xps 420 noisy fan black screen
Dell xps 420 try to switch on lots of noise sounds like fan going round butonly lights 1,3,4 show. Screen totally black no life it seems . Is it dead?
  • Anonymous Jul 04, 2012
    Have just tried holding the power button in for 15 sec with the power turned off and the lights came on 1,2,3 but still nothing - however a message did display on the little window saying no display device found....
Friendly PC Repair
Level 3:
Genius:
  • Dell Master 1,274 Answers
  • Posted on Jul 04, 2012
Friendly PC Repair
Dell Master
Level 3:
Genius:
Answers
1274
Questions
Helped
261796
Points
3736
More than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
    thanks for the info .... me being a bit of a computer novice....'bios' whats that? My main concern is that i would have lost the data (photos etc) do you think thats the case? Is there a way to check this bios thing or do i need to take it to a pc repair shop?
  • Friendly PC Repair
    Friendly PC Repair Jul 04, 2012
    when you turn it on it says 'press a specific key to enter 'setup' set up is bios. i doubt it's the hard drive, it may be something as simple as a fan going out
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Jan 05, 2009
SOURCE: dell xps 420 desktop want go into windows mode or reboot
Try clearing the motherboard state:
unplug power cable
hold power button 15 seconds
release power button
plug in power cable
start as usual
As much as these issues can be as drastic as noted above, this is rarely the case.
finnaly, please post some more info, do any lights come on?
The power light can be different colors and may blink, and there are diagnostic lights on the front (usually marked 1,2,3,4).
Anonymous
  • 3 Answers
  • Posted on Jun 24, 2009
SOURCE: xps 420 keeps freezing or going to blue screen
change/clean the cpu fan or try to reduce heat arround the processor
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Jan 04, 2010
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Anonymous
  • 3940 Answers
  • Posted on Apr 03, 2010
SOURCE: dell xps 420, won't finish loading bios boot
see if this info helps narrow down the failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Anonymous
  • 78 Answers
  • Posted on Apr 29, 2010
SOURCE: Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Xps 420 fan
as long as it has the same connector than yes. fans are usually the same when it comes to personal computers
Xps 420 start up problems error codes 1 and 3
Dean Fowler,
The 1-3 error code that you are saying that your computer is making represents a Video Memory Test failure. Try reseatting the video card in your computer or replace the video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Xps 420 air temperature sensor
I would remove your fan & heat sink to check that your thermal paste isn't dry first.
DELL XPS 420 Fan noise, and goes into sleep mode
Maybe the fan is going bad. Open the case and check it to make sure it is tight by tightening the screws. Also make sure a cable or wire is not hitting the fan blades causing the noise.
Go into the Power Option in the Control Panel and set your Sleep or Hibernate options up higher or set them to NEVER.
Click Start/Control Panel or Start/Settings/Control Panel and look for Power Options.
Alert chipset heat sink not detected system halted dell xps 420
Sounds like your heatsink which is inside the computer and sits on top of the CPU is bad. There will probably be a fan that sits on top of the heatsink.
Look on ebay and purchase one for your system.
http://www.ebay.com
I found a new one below on ebay for $14.95 (the link is below)
http://www.ebay.com/itm/New-OEM-Dell-Dimension-9100-XPS-420-430-Heatsink-Assembly-XP850-/350520689627?pt=LH_DefaultDomain_0&hash=item519ca943db
I have Dell destop model XPS-420 my computer is not getting on NO FAN and no noise please advise me what should I have to do
hi
are you saying the fan is not working ? if that's the case, you need to replace the fan.
get the service tag # located on back of your desktop PC, go to this link below, place service tag in appropriate box . it will give you part numbers for the peripherals of this computer. locate the fan and purchase replacement.this is all you have to do. DO NOT TURN ON THE COMPUTER UNTIL THIS FAN IS REPLACED, or you will damage the mainboard and/or CPU.
http://search.dell.com/results.aspx?smh=sup&c=us&l=en&s=dfh&k=XPS-420%20&cat=sup
3helpful
Xp420 dell doesnt boot just a solid amber light on mother board high rpm on fan that doesnt slow no picture on screen....?????
Solid Amber light is a No-Boot scenario for all DELL PC. It may be either Power Supply, motherboard, memory or Proc. If you try to call Dell customer support they might try to let you isolate the problem by opening up your pc. But they will replace the parts necessary if they found out that its broken and your XPS is still under warranty.
You can call 1-800-232-8544 be sure to have you Service Tag or Express Service code ready.
1helpful
3answers
4helpful
2answers
From Me:
Why?
1helpful
2answers
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
